Moderators: oldjapanesebikes , H2RICK , diamondj , Suzsmokeyallan
Posts: 4316 Joined: Mon Dec 13, 2010 4:32 pm
Post
by jabcb » Fri Jul 26, 2019 11:16 am
Have a nice scissor lift with adjustable adapters. Was a bit of bummer that the adjustable adapters do not extend enough to get past the 3-into-3 expansion chambers & reach the frame of my GT380.
Recently picked up another scissor lift, the Black Widow BW-PLHD ProLift.
https://www.amazon.com/Black-Widow-BW-P ... ref=sr_1_1
The adjusters aren’t adjustable, but two different lengths are provided. The longer one provides about 1/4” clearance to the lowest expansion chambers.
If you go this route, make sure to use tie down straps at the front to provide stability.
Lift_1126 by
jabcb , on Flickr
Lift_1127 by
jabcb , on Flickr
sportston
Posts: 1155 Joined: Wed Jul 10, 2013 12:04 pm
Country: England, UK
Post
by sportston » Wed Nov 17, 2021 3:28 pm
I found a similar problem with my jack too. I just use my centre stand now. It took a lot of modification to clear the centre expansion chamber.
Posts: 3256 Joined: Thu Feb 16, 2012 11:50 am
Post
by Alan H » Wed Nov 17, 2021 5:34 pm
I just cuss and struggle..........
rodent
Posts: 47 Joined: Wed Feb 14, 2018 3:15 pm
Suzuki 2-Strokes: '73 GT750
Post
by rodent » Fri Nov 19, 2021 1:45 pm
I had the same issue, I put a couple of nuts in the tube to raise the height of the adapters.
