WTB: GT550 Carb crank arm
r3tro74
Suzuki 2-Strokes: 74 GT550
Post by r3tro74 »
Anyone have one of these they want to sell?
Thanks,
Bryan
1974 Suzuki GT550
1983 Honda XL250
2002 Yamaha Bear Tracker
1959 Lone Star Malibu
Re: WTB: GT550 Carb crank arm
Those are notorious for breaking. Especially if you spread them to make removal from the shaft easier. Believe it or not, that part is still available from Suzuki. 13564-33110. $33 and change from Dillon's. http://www.powersportspro.com/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I had 3 good ones at one time but have since given them away. One went all the way to Norway.
There is a repair I have seen done. Drill a 1/8 hole through the arm and shaft. Install a 1/8 roll pin in the hole.
r3tro74
Post by r3tro74 »
Thanks for the roll pin idea, I'll try that for a temp fix. I am hoping someone has a used one and maybe save a few bucks and do some "recycling "
1974 Suzuki GT550
1983 Honda XL250
Yes it works. I repaired and tuned a set of carbs for a guy one time. He sent them to me in the mail. One of the arms was pinned. Seemed to work just fine that way.
markush
Country: Germany
Suzuki 2-Strokes: GT250/380
Post by markush »
Hello!
I'm from Germany and screw on GT250/380.
By searching for the carburetor-arms I found this topic.
No one wanted to sell me used and new ones are too expensive with this built-in breaking point.
So I finally came up with the following repair method:
Using adjusting rings (DIN 705, Ø 10 x Ø 20 x 10 mm)
connected to the arms instead of broken clamps.
Image Image Image
bye
JoeKuchnicki
Country: United States
Suzuki 2-Strokes: 1974 Suzuki GT550
Post by JoeKuchnicki »
I'm not able to see the pictures posted on Markush post....
markush
Country: Germany
Post by markush »
try this
http://suzuki-gt380.de/gt380_dateien/motor/Vergaser/
click files "Hebelarm_Rep....")
Note that the first 5 posts were 11/12 years ago.......
