needed- T500 oil pump cable terminal piece
sbaugz
Suzuki 2-Strokes: T500, S32-2, GT185
Post by sbaugz »
Its part number 13683-51010
nobody seems to carry it. Its the little barrel piece (terminal cable) that attaches throttle cable to oil pump lever arm.
Re: needed- T500 oil pump cable terminal piece
I checked a local Suzuki dealer’s online system & it said its available.
Did you check with your local Suzuki dealer?
If the dealers can’t get it & no member has a spare, then the you-have-to-wait-longer option is Discount Bike Spares in the UK:
http://www.discountbikespares.co.uk/our ... 00250.html
sbaugz
Post by sbaugz »
false alarm. After another hour of frantically looking, I found that little bastard part. Thanks.
ConnerVT
Post by ConnerVT »
Yep. That part is a bastard to find.
I hate that. You get so desperate you start looking under stuff that hasn't been moved in 3 years. The worst one (imo) is the E clip that goes in the gas cap hinge pins. If you order one, they should send you a bag of 10.
I found a way of capturing a few on removal. I take a strip of packing tape and stick it together inside out. Then stick a few of those around the fillers neck. The clip usually sticks to the tape when you pop it off. Of course you will probably loose it later when attempting to put it back on. PLING! ^#*+@**:]. :evil:
Those little E clips are available at radio controlled model shops for pennies.
bs_racer
Post by bs_racer »
Years ago when I worked in a motorcycle shop, we used to call those "damn it clips".
Worrying is simply praying for something you don't want.
