*Wanted* Suzuki GT550 rear engine spacer ##FOUND##
Rustygt550
Post by Rustygt550 »
As the the title says, I am looking for a GT550 rear engine spacer as the PO must have forgot to put it in when he had the engine out :shock:
A member of the Kettle clinic, kindly sent me a nice zinc plated spacer!
Madbuffalo
Suzuki 2-Strokes: GT750
Re: *Wanted* Suzuki GT550 rear engine spacer
Post by Madbuffalo »
Rustygt550 wrote:the PO must have forgot to put it in when he had the engine out :shock:
That's an extra part, right? :lol:
You need the spacer that the rear upper engine mounting bolt goes through? Suzuki shows its part number (09180-10030) being the same as for the GT750. If that's the case I'm sure I have one, although shipping from the states may be more trouble/money than it's worth?
1974 Suzuki Nomad 340
Rustygt550
Thanks for the info, the spacer is no longer available, maybe I will be able to find a spacer this side of the pond
Rustygt550
Just went out & had I look at the engine( it's out of the bike at the moment awaiting strip down over Christmas holidays). It turns out its the lower rear engine spacer. I put the part number into my Suzuki parts cross reference & it also fits the gt750
Madbuffalo
OK should have that one too. Let me know if you don't find anything your side of the world, glad to help if I can. :)
Cliff
Post by Cliff »
Just looked at the spacers out of the GT550 engine that I have on the workbench. The upper and lower are both the same. 10.2mm ID, 16mm OD, 107mm long. If you can't find an original, cut a piece of pipe to fit.
Cliff.
