Hello,
I just discovered the PO had JB welded one of the carb bowls on my T500K....must've been leaking. Anyway I'd love to get a decent carb bowl if anybody has one kicking around. I don't need any other carb parts.
Also WTB a tripmeter reset knob for same bike....methinks this will be tougher to locate, probably many of them got lost over the years.
Thank you.
Peter
T500K carb bowl and tripmeter reset knob - WTB
- Suzuki 2-Strokes: T500K
- Fritz500
Re: T500K carb bowl and tripmeter reset knob - WTB
These folks have the knob and screw listed:
http://www.robinsonsfoundry.co.uk/conte ... speedo.htm" onclick="window.open(this.href);return false;
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
Thanks, that was helpful. I went to their site and found (and purchased) some other OEM parts I needed.Fritz500 wrote:These folks have the knob and screw listed:
http://www.robinsonsfoundry.co.uk/conte ... speedo.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Peter
Here are some pics.pipelinepete wrote:Hello,
Thank you.
Peter
Shouldn't the carb bowls be different? The overflow and drain fittings are on the same side, seems kinda odd to me....how would you drain the RH carb with this setup?
Peter
- ConnerVT
- Novice racer
Nope. Same bowl for both left and right carb.pipelinepete wrote: Shouldn't the carb bowls be different? The overflow and drain fittings are on the same side, seems kinda odd to me....how would you drain the RH carb with this setup?
Even harder to drain on the earlier models, as the carbs are tucked closer to the engine (due to the shorter intakes). I pulled the carbs off to drain them this year, as I had other stuff to work on this winter anyway.
