75 GT550 clutch
tennesseetwostroke
Suzuki 2-Strokes: GT550L x2 TS400
75 GT550 clutch
Post by tennesseetwostroke »
Does anyone know if there is a washer behind the clutch assembly or does it ride against the bearing ? I am building a 74 motor with the clutch from a 75. The shop manuals I have, old Clymers, show a washer in the back. Neither motor had one when I disassembled them.
smoketriples
Suzuki 2-Strokes: GT750
Re: 75 GT550 clutch
Post by smoketriples »
Here's the fiche: #3 is a washer http://www.partzilla.com/parts/search/S ... parts.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Smoketriples
current stable:
'75 Zooki GT750 (rider)
GTandcbr
Country: WALES
Re: 75 GT550 clutch
Post by GTandcbr »
You need to look at GT26 here
http://www.ozebook.com/compendium/techbuls/" onclick="window.open(this.href);return false;
98 carb Blackbird and GT550j
tennesseetwostroke
Re: 75 GT550 clutch
Thanks for the replies. Every diagram I see is different. The service bulletin on the upgrade to the newer borg warner starter bearing looks like it does not have one. The primary and driven gear line up almost perfectly so hopefully I have it right.
Re: 75 GT550 clutch
I'd buy the old clutch off you but the postage would be a killer I think.
TonupKid52
Country: uk
Suzuki 2-Strokes: gt550 gt750 rg500 h2b z1 916 x7 sb200
Re: 75 GT550 clutch
Post by TonupKid52 »
Hi The part number is 08211-22503 there are some for sale on ebay. this is the washer between inner and outer casing on the clutch.
The other one is part number 08211-22423 this is the one behind clutch.
Hope this helps.
Ray
