Swing arm bolt query - GT750J
Posted: Sun Apr 20, 2014 3:35 am
by MikeH1A
Hi, Just a quick question re the swingarm bolt. Is there a particular torque setting this should be done to or just tight as you can get it sort of thing?
Re: Swing arm bolt query - GT750J
Posted: Sun Apr 20, 2014 5:42 am
by GT750Battleship
8) Hi,G'day from Sydney,how's things,this info found on nett,45ft lbs for the swing arm 8)
(Suzuki Service Bulletin May 1976)
Posted: Sun Apr 20, 2014 5:41 pm
by MikeH1A
Many thanks for that helpful bit of info. All good over here - now that the sun has come out (been raining and flooding around the city!). So ... did you head to the zoo and have a chat with Wills and Kate?? :lol:
Posted: Sun Apr 20, 2014 8:50 pm
by Suzsmokeyallan
Some early swing arm bolts were not threaded enough and gave a false torque setting. Make sure the washer covers the first few threads off the frame by the nut side. If it doesn't, add a washer under the bolt head on the other side. I actually prefer to have a washer under the bolt head anyways.
Posted: Tue Apr 22, 2014 9:04 pm
by MikeH1A
Good tip re the bolt and washers. I'll ease the nut off and check where things are at. Ta
