Can anyone identify these chambers? To me they look like J&R, but these have removeable headers.
Chamber identification!
Hello!
- Country: united states
Re: Chamber identification!
Maybe Denco. I haven't seen any with clamps on the head pipies like yours. I have a set of Bassani chambers that are very similar.
I had hoped the setup would have been more narrow, but this is the only combination I can find working.
Mount them on the inside of the frame mounting point.
2007 Suzuki V-Strom DL650
Can't do that as they are
Doesn't look quite right does it. I would have expected the centre pipe to fit either underneath the right side one rather than beside it.
So did I, but this is the only way I have found that works
They do look similar to J&R which have similar flanges and removable headers, but they look longer than J&R and the mounting brackets are different.
I have seem side by side pipes from time to time but they really need to be tucked in closer than that.
I thought J&Rs too, however the chambers for the 380 and 550 have two-stage divergent cones. I must say I don't recall ever seeing a set of J&Rs for the 750.
Did Ocelot make pipes for the GT750? The ends remind me of the removable baffles on Ocelot pipes.
Yes Ocelot made Chambers For the 750 and I scavenged 2 sets of them. They are very fat and low to the ground.
