Genuine Mikuni Part Numbers?
avc8130
Country: United States
Suzuki 2-Strokes: '75 GT550
Post by avc8130 »
Does anyone know the genuine Mikuni parts that fit the carbs on my GT550?
The "box of carbs" I got from the previous owner is missing a few key components (float hinges, needle seats, pilot jets, bowl gaskets).
I thought about the Ebay kits, but got laughed at :evil:
Parts to the Suzuki part numbers appear to be ~50% higher than they should be, and when multiplied by 3 it adds up fast.
I know these are VM28 "SC" carbs, but which needle/seats do they use?
I think I found the float hinges affordably.
Pilot jet style?
ac
Re: Genuine Mikuni Part Numbers?
:? Hi,you could try these guys...nrp-carbs.co.uk
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Post by old racer »
Maybe these guys can help you.
http://www.allensperformance.co.uk/mikjets.html" onclick="window.open(this.href);return false;
jeff kushner
Suzuki 2-Strokes: none
Post by jeff kushner »
Here in the States, Pat's has the cheapest prices for most parts, he's a little high on the slides but good on everything else.
Home page:
http://www.psep.biz/index.htm" onclick="window.open(this.href);return false;
Mic parts;
http://www.psep.biz/store/mikuni_vm_type_parts.htm" onclick="window.open(this.href);return false;
Listen, you have to scroll down till you get to the BLUE LINKS for each part you need to look at!!
jeff
avc8130
Post by avc8130 »
Jeff,
That's perfect, thanks!
How do I know what size needle/seat I need?
ac
Lots of specs you need are right here on this page .................viewtopic.php?f=2&t=6147" onclick="window.open(this.href);return false;
avc8130
Post by avc8130 »
Coyote wrote:Lots of specs you need are right here on this page .................viewtopic.php?f=2&t=6147" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
While that might be true, I don't think the needle and seat size are there. I could be missing it, though.
ac
2.0 is the size. They look the same as an RD350/400 Yamaha and that I think is VM262620
avc8130
Post by avc8130 »
tz375 wrote:2.0 is the size. They look the same as an RD350/400 Yamaha and that I think is VM262620
THANK YOU!
Any idea if the pilots are VM22/210 or VM28-1001?
ac
VM22/210 for sure on 550 / 380
avc8130
Post by avc8130 »
Sweet! Once I can figure out how to get the float hinges added to my "cart" I should have everything I need to slap these back together!
ac
