Broken oil line
- Suzuki 2-Strokes: 1972 GT 380, Harley FLHK
Broken oil line
Have a single broken line on my Gt 380. Removed all the lines so I could get to it. Break is half way thru and is the only place it leaks.. Any suggestions on epoxy to repair it. The check valves all work. Have a spare but its not in as good of shape as mine (except for the one crack).
Re: Broken oil line
If I was to keep a broken line, I would sleeve it with clear tube that resists oil and heat and seals by having a small ID than the OD of the original pipe. Nothing much actually sticks to that OE plastic!
The lines are so low pressure that so long as the sleeve was resilient I see no reason why it should not last for years.
Re: Broken oil line
A short length of model airplane fuel line, but you will have to break it in two to get it on there.
Re: Broken oil line
Id prefer to sleeve it with a piece of brass tubing, member "oldjapanesebikes" has effected some similar repairs so you should contact him about what glue to use.
Re: Broken oil line
Agreed. Chris (Coyote) first suggested the brass yube method, and somewhere on this board there are a load of photos showing what he did. I also wrote about it at this link:Suzsmokeyallan wrote:Id prefer to sleeve it with a piece of brass tubing, member "oldjapanesebikes" has effected some similar repairs so you should contact him about what glue to use.
http://oldjapanesebikes.com/blog/2012/0 ... ion-lines/" onclick="window.open(this.href);return false;
Re: Broken oil line
These pics? Not brass. Started life as a 1" long section of 1/4" aluminum rod from the hardware store (had to buy 3'). Drilled through to the line ID. counter drilled 7/16 from each end to the line OD. Roughed up the line surface for 'tooth'. Used standard 15 minute epoxy applied to the line OD only so that none would squeegee into the through hole.
Re: Broken oil line
Very neat job
Re: Broken oil line
Thank you everyone one for you suggestions and help
. One of these days I'll get her back on the road.
Re: Broken oil line
Yep - those ones - thanks again for the idea Chris. So far its working well !Coyote wrote:These pics?
