Hello,
I've been browsing this forum for a few months now and have found a ton of useful information. But, I've finally come across something that hasn't been discussed much that I need some help on.
A friend and I are in the process of a 1972 T350 Cafe build. Things are going exceptionally well, but we are struggling with adapting the rear sets to work. I bought a set of universal rear sets that are pretty standard and include all the usual linkage necessary. But, we seem to be struggling with how to make the brake work with the cable driven drum.
Any insight, places to search, advice, etc etc would be greatly appreciated.
I'm unable to attach photos, but here is a link to a guy who made some custom rearsets for his gt250. Picture of brake side rear set is about 1/4 of the way down... Not sure what parts he used to get that set up to work.
http://www.dotheton.com/forum/index.php?topic=12787.105" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
T350 Rear Sets
- Suzuki 2-Strokes: 72 T350, 98 Bandit S
Re: T350 Rear Sets
What exactly is the problem? The guy on DOT has cut down the stock pedal, and attached a rod to it to push it forward when the new pedal is depressed.
Re: T350 Rear Sets
I guess I was just wondering how he attached the rod to the stock brake lever...I couldn't tell if he use some sort of split end with a pin through it? Our set came with 4 ball joints and jam nuts. I guess we could just drill a hole through the brake lever and run the bolt through that?
Also, Titan, does your company happen to make any T350 specific rearsets?
Re: T350 Rear Sets
Sorry we don't.....I would have already suggested it if we did.
You are right about fitment of the rod. Drill through and nut and bolt the rose joint to the old lever.
