T500 handle bar riser bushings
- Suzuki 2-Strokes: T500 GT550 RM125 RM250 TS250 RM400 CR250,
Are the handle bars supposed to have a "loose feel" up and down movement? I read another post saying the movement is normal to minimize vibration. I thought maybe the triple clamp riser rubber bushings were worn (which they probably are). Any remedies to tighten the slack up some without changing the rubber bushings? I hear it's a pain in the a** to change the rubber bushings. Thanks in advance guys!
- Country: United Kingdom
- Suzuki 2-Strokes: T500J
Re: T500 handle bar riser bushings
Mine were too loose when I got my bike. As far as I could tell new ones weren't available, so I bought these
http://www.discountbikespares.co.uk/our ... -AP50.html" onclick="window.open(this.href);return false;
I seem to remember that they were fractionally too long but otherwise fitted, so I ground them down in length.
Fitting was easy, I just had to hammer out the old ones with a suitably sized socket, clean up the hole and tap in the new ones
I guess it really hinges on the definition of "loose". There is meant to be some play for the reason that you mention - in fact, I think Mother Suzuki was quite proud of this innovation. It is a bit disconcerting when you first ride the old girls - it initially seems to be wrong/unsafe/unnatural (choose the word that fits). However, I found it didn't take long to get used to. They shouldn't be sloppy or excessively wobbly though.
72 GT750J
71 TS250R
71 H1A
72 GT750J
71 TS250R
71 H1A
Did it seem to take the play out of it or was still about the same? Mine may be normal just don't something to compare it too from one that's normal.tricky1962 wrote:Mine were too loose when I got my bike. As far as I could tell new ones weren't available, so I bought these
http://www.discountbikespares.co.uk/our ... -AP50.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Would these work?
http://www.ebay.com/itm/New-Handlebar-M ... 3f3819b3fb" onclick="window.open(this.href);return false;
At the annual safety test (MOT), the inspector said get it fixed pronto, he was worried about the bars hitting the clocks if they got any looser
Yes, they firmed the bars up quite considerably, there is only very slight play now
Would these work?
http://www.ebay.com/itm/New-Handlebar-M" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; ... 3f3819b3fb
Same part number - need shortening
Would these work?
Thanks Tricky. Did you knock them out from top to bottom without taking the tree off the stem?
I think so, it was a couple of years ago.
I have just found one of the old ones I took off and I have misinformed you.
The new bushes didn't need shortening, they needed the ID boring out to 11.5mm so the bolts could fit through. Sorry about that
Ahh ok.. Did you just drill them? Could I just use those bushings and risers from a GT500?tricky1962 wrote:I think so, it was a couple of years ago.
Yes I just drilled them.
I see no reason why you can't use the risers from a GT500 providing they fit your handlebars - just more bits to buy so more cash - hence cheaper to bore out the new bushes.
OK thanks. What size bit did you use? I would need to do a SAE conversion.tricky1962 wrote:Yes I just drilled them.
A 15/64" should be big enough. I suggest you take a riser off and measure the stem
Thanks for the help!tricky1962 wrote:A 15/64" should be big enough. I suggest you take a riser off and measure the stem
