Just remember, no question is silly! It's only silly NOT to ask!
The starter is on the underside of the engine. It has a cover over it held on with 4 bolts. You will have to drop the exhaust to get to it! Under the left hand plastic side cover you'll find the starter solenoid. It has the main, large red positive battery wire going to it and one large/heavy black wire out of it going to the starter. With a good battery installed, put a jumper between those two large terminals and the starter SHOULD come to life! Or you could just get a bunch of sparks or nothing at all. Sparks or nothing means the starter is bad. If the starter turns but not the motor, the starter clutch has failed.
The right hand throttle grip should look like this:
http://www.ebay.ca/itm/SUZUKI-GT250-thr ... ac&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
The transmission drain plug is the one that goes straight into the bottom of the case, not the one that goes in on an angle!
Here's a link to a manual that's good. I have one and it's better than the Haynes manual.
http://www.ebay.ca/itm/Clymer-Suzuki-38 ... 70&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
And don't be afraid to ask questions!!
Cliff!
