finally started it! a couple issues
Posted: Sun Feb 08, 2015 12:49 pm
by mikefealk
started right up finally. coolant is leaking heavily from the #3 head bolt
http://cdn.partzilla.com/diagram/suzuki/02/118/0001.png" onclick="window.open(this.href);return false;
even with it not running it is still coming out around the washers on top of the head. is there supposed to be a sealing washer on that bolt? i didnt use any no leak in the cooling system. HELP!
Re: finally started it! a couple issues
Posted: Sun Feb 08, 2015 1:19 pm
by Coyote
If I remember right, all 11 head bolts use sealing washers. Part #11?
Posted: Sun Feb 08, 2015 1:30 pm
by mikefealk
later years used those to try and fix the stud corrosion issue from water coming in. im talking about the 8 mm head bolts, i dunno if they ever made sealing washers for those.
Posted: Sun Feb 08, 2015 3:45 pm
The issue here is that on a stock barrel, all of the 8mm holes are "blind". In other words the bottom end is closed. No water can get into those bolts.
What happens is that people fit bolts that are too long and when they tighten them down, the bolt burst out of teh bottom into teh water passage allowing it to leak.
The simple fix is to slather them in your favorite gasket goo and use a soft aluminum or copper washer with goop under the washer to try to seal them.
Posted: Sun Feb 08, 2015 4:17 pm
by GT750Battleship
:? Hi,did you use a genuine head gasket ? some after market ones are prone to leak past the bolts....just a thought :?
Posted: Sun Feb 08, 2015 4:20 pm
by mikefealk
oh no, moto gp your saying that the threaded hole for this 8 mm bolt is broken out into a water passage. thats not good news.
Posted: Sun Feb 08, 2015 4:26 pm
by pearljam724
When I rebuilt my 750 motor. I replaced the lock and flat washers with stainless steel ones. They didn't have sealing gaskets around the interior of the flats and don't leak.
Posted: Sun Feb 08, 2015 5:42 pm
by Coyote
I think TZ has the answer. Broke through to the water jacket. Regular old pipe dope that you use around the house on galvanized pipes should seal the bolt threads just fine.
Posted: Sun Feb 15, 2015 7:53 pm
by mikefealk
Well I added two tablets of bars leaks to the cooling system and no more leak! Don't really like the thought of it but the manual says to. She's running good! Pics to come just doing heat cycles and break in now
