gt 750 pushrod / pressure plate error?
dyrberg123
Country: Denmark
Suzuki 2-Strokes: T350 GT750 T125 RG250 RD125lc RD350lc RD400
Post by dyrberg123 »
As i am taking the engine apart i was doing the clutch yesterday. I have a lot of experience on two strokes, but first time gt750. When dismantling the clutch pressure plate the push / pull rod did fall out of the bearing, so question is, is this a really loose fit :?:
Bearing looks okay, so does the stubshaft...
If it's not broken - don't fix it. Why not?
Re: gt 750 pushrod / pressure plate error?
Good question. They are all like that and I suspect that was Suzuki's version of a self aligning shaft and bearing to allow for tolerance stack up.
dyrberg123
Country: Denmark
Thanks TZ..
