blanking off SRIS GT 750
dyrberg123
Country: Denmark
Suzuki 2-Strokes: T350 GT750 T125 RG250 RD125lc RD350lc RD400
Post by dyrberg123 »
Hi guys,
I am about putting my engine back together, and found some of the sris vavles not working, and one of them is
blocked, so I was thinking if i should blank them off? Do any have experience doing this and what speaks for it, and what doesn't?
If it's not broken - don't fix it. Why not?
Re: blanking off SRIS GT 750
They need to be blocked off in two places - crankcase end and barrels.
On the crankcase, just use a suitable allen Cap head) screw with a sealing washer and maybe some gasket goo. The cylinders have pressed in fittings for the SRIS lines. I remove them and tap the holes to take grub screws. You can use a bolt or cap screw if you prefer and do not forget the one under the intake port on later barrels.
dyrberg123
Country: Denmark
Hi TZ,
Have you blanked off your own and why, and does it have any down sides?
I have done three motors that way so far and no downside worth talking about In theory the bike may smoke slightly more on one cylinder than the others, but I don't see that as a downside.
dyrberg123
Country: Denmark
Thanks TZ.
Btw how do you remove the barrel ones? Grab them with a pliers or side cutter or drill them?
Pull and twist at the same time - pliers.
dyrberg123
Country: Denmark
