Guys is there a trick to getting the center pipe exhaust couplers not to leak? I cant seem to get them not to. I have replaced the couplers and not over tighned them but they seem to always leak. Any tricks?
GT750 Exgaust Coupler LEaks
- Desert_75
- Suzuki 2-Strokes: '75GT750, '79CX500, '08ZX-14
Re: GT750 Exgaust Coupler LEaks
I used to put a small bead of high temp RTV on there when I had my stock exhaust. Any damage to the coupler's?
Fit slightly oversize O rings.
You'll have to use ratchet straps around the 2 outer pipes to get them to locate though.
I did with the 550 anyway.
Mine also leaked until I put the RTV on it. Seems to do the trick. //Pat
1973 GT-750
1974 Yamaha 360 DT1
1998 Kawasaki 750 Vulcan
1974 Yamaha 360 DT1
