Battery for a GT500
- Suzuki 2-Strokes: GT500, Harley Davidson V-ROD
Battery for a GT500
Hi guys,
I am building a GT500 cafe racer and concidering putting the battery in the seat hump. What is the smallest battery i can get away with?
GT500 Café Racer build website https://jtccc.wordpress.com/" onclick="window.open(this.href);return false;
Re: Battery for a GT500
It would depend upon the size of the seat hump, buzzer
Although a 140 Ah truck battery would be rather extreme a lead acid battery of 5 - 7 Ah should be easily enclosed.
Cheers Geoff
Cheers Geoff
If you are going to use an AGM or maintenance free battery, then you also need to upgrade to a modern rectifier/regulator.
As small a hump that I can get away with GeoffZunspec4 wrote:It would depend upon the size of the seat hump, buzzerAlthough a 140 Ah truck battery would be rather extreme a lead acid battery of 5 - 7 Ah should be easily enclosed.
Cheers Geoff
Thanks, that's Interesting, not thought about that... I would like to use a small maintenance free battery, do you have any links or information on what I need to upgrade the rectifier?jabcb wrote:If you are going to use an AGM or maintenance free battery, then you also need to upgrade to a modern rectifier/regulator.
I will be making my own loom, so any other upgrades can be catered for while doing this, happy for any suggestions.
The bike has not run for 30 years, so I am not sure about the ignition side of things yet...
On both my TS400 and my GT750, I have successfully used sealed batteries. My GT has a 2AH battery from something .... I bought it for it's size. Since I don't use the electric starter, it's fine. I've had no charging problems. On the TS400, I used the early 12v electrics, with a GT750 rectifier, and a GT500 regulator. I don't remember how I wired it, but it worked fine.
What is the reason for that, jabcb? I Fitted an AGM to my Seeley Honda 750 which still has the original reg./rect. and wouldn't want to mess it up.jabcb wrote:If you are going to use an AGM or maintenance free battery, then you also need to upgrade to a modern rectifier/regulator.
Cheers Geoff
- ConnerVT
- Novice racer
Can't speak for the Honda electrics, but the Suzuki charging systems up through the 1970's tend to generate a higher voltage than a sealed AGM (glass mat) battery can tolerate. In fact, in the smaller displacement Suzuki, they would omit the voltage regulator completely, and use the battery to regulate the voltage.
A lead acid wet battery is much more forgiving of high voltages. It will generally just "boil" the electrolyte, which you would regularly need to refill. And stain your chrome.
A glass mat, maintenance free battery, when exposed to high voltages, will also boil of the electrolyte, drying out the mats, which you can not refill.
Thanks Connor,
I'd better check the voltage output on the Honda to be on the safe side.
Cheers Geoff
Cheers Geoff
When charging a sealed battery off the bike, you're not supposed to exceed 14.1V because above that voltage, the electrolyte starts to give off gas which it cannot vent ... so I think around max 14 across the terminals at 4,000rpm is the max you should have
- ConnerVT
- Novice racer
Voltage is correct. But AGM do have a vent. But they contain less fluid (by volume) than traditional lead-acid batteries. The issue is that the electrolyte cannot be added to AGM batteries, which will find its way out the vent as gas and vapor.
You could do away with the battery altogether? Fit a battery eliminator, and use whatever seat unit you like....
The T500/GT500 use a pretty lame voltage regulator. It is considered normal for voltage to get up to around 16V. That is too much for an AGM battery.
I use a Tympanium rectifier/regulator on my T500.
Its popular with the vintage Triumph guys & costs around $50.
Not sure what alternatives are readily available in the UK.
The GT750 has a car-style alternator. Properly adjusted it can control voltage much better.
Oregon motorcycle parts has modern upgrades for the GT750 rectifier & regulator.
AGM battery manufacturers generally recommend max voltage around 14.7V. (Does vary a bit.)
The GT500 has PEI — the ignition is completely separate from the alternator/battery circuit.
The GT500 will run just fine without the battery.
The T250/T350/GT250/T500 have permanent magnet alternators — some of these bikes will start & run OK without a battery.
Running these bikes without the battery is a big NO-NO.
They use the battery to control voltage.
A few years ago I checked the timing on the T350 in my avatar pic.
Got interrupted.
When I got back to it, I started the bike with a disconnected battery.
Started & ran fine but it blew out all the lights except for the turn signals!!!
Got interrupted.
