Carb question
- Country: england
- Suzuki 2-Strokes: gt185 ec
Carb question
I took off the carbs on my gt 185 today and a small chrome washer fell out of the choke side carb when I turned it over. The rhs bowl is not the same as the left as there is a cast in tube on the choke carb bowl. There is also a brass tube from the main carb body that inserts into this cast-in tube. Question is, is that where the little chrome washer fell from, I.e does the washer slip over the brass tube??
- Country: WALES
Re: Carb question
http://www.partzilla.com/parts/search/S ... parts.html" onclick="window.open(this.href);return false;
Does this picture help?
98 carb Blackbird and GT550j
- Country: england
Re: Carb question
Thanks, but I've looked at this already and others and they're not very clear. I found an auction site advert of a completely dismantled and cleaned set of carbs and I can't see the little washer in that either but the bowls and tubes were the same as I described. I can't think what the washer would do but I'm sure it fell out of the main lhs carb body when I turned it it over (with the bowl off) and there is no washer that I can see on the rhs carb body.GTandcbr wrote:http://www.partzilla.com/parts/search/S ... parts.html" onclick="window.open(this.href);return false;
Help!!
- Country: WALES
Re: Carb question
Have a look here
http://www.wemoto.co.uk/bikes/suzuki/gt ... epair_kit/" onclick="window.open(this.href);return false;
Is that the washer? If so I think that is the jet gasket
- Country: england
Re: Carb question
Hi, if you mean the one shown above the circlip , then no! It's the same size as the circlip though if that helps? I've taken a couple of pics but I'm not sure how to upload them on this siteGTandcbr wrote:http://www.partzilla.com/parts/search/S ... parts.html" onclick="window.open(this.href);return false;
- Country: WALES
Re: Carb question
You will get a message saying the site has reached its quota you need to use photo bucket or similar then post the link.
- Country: england
- Country: england
Re: Carb question
It looks like a washer from the float bowl securing screws.
- Country: england
Re: Carb question
Wish it was mate, but they're split rings and all accounted for!Zunspec4 wrote:It looks like a washer from the float bowl securing screws.
Re: Carb question
I use a plain + split on mine so I thought it may have been a possibility
Should there be a washer under the main jet ? Is one side missing?
Cheers Geoff
Cheers Geoff
- Country: england
Re: Carb question
I don't know, it's possible but I can't see anything on any of the schematics I've found.Zunspec4 wrote:I use a plain + split on mine so I thought it may have been a possibility![]()
Cheers Geoff
I can't think what it might do either, but even with my limited knowledge of carbs and how they work, I imagine it's the difference between running normally and having a host of problems.
Any other thoughts ?
- ConnerVT
- Novice racer
Re: Carb question
Just because you found it in there, doesn't mean it was supposed to be there.
- Country: england
Re: Carb question
I'd like to think the same to be honest but wondered if anyone could put my mind to rest.........ConnerVT wrote:Just because you found it in there, doesn't mean it was supposed to be there.
Re: Carb question
There is no reason to have a washer inside the float bowl that I can think of. Those carbs have an enriching circuit in one carb and the other one draws fuel from the one with the "choke". I suspect that washer dropped in there when someone had the carbs apart.
