Gt500 twist grip
- Suzuki 2-Strokes: GT500, Harley Davidson V-ROD
Gt500 twist grip
Anyone help me? Just assembled my twist grip and i notice that there is no positive stop in the closed position. Am i missing some parts? Any of you guys got any pictures?
GT500 Café Racer build website https://jtccc.wordpress.com/" onclick="window.open(this.href);return false;
Re: Gt500 twist grip
Ok, i have had a few beers... Started the bike tonight, first time its run since 1986!titan performance wrote:Not sure what you mean Buzzer?
What i mean is, in the closed position, i can turn the twist grip clockwise, there does not apear to be a stop to prevent this, like on other bikes i have had. The twist grip was off the bike and in bits when i bought it, so i may be missing parts.
On. A lot of twist grips, the cable end piece that screws into the twist grip is the "stop" for the drum.
If you don't screw the cable end pice in fa me not ugh it won't perform this function.
Hope this helps
Andrew
Hope this helps
Andrew
Damn I pad keyboard,
Should have read, if you don't screw it in far enough.
Andrew
Andrew
Thanks Andrew. I had hope when I read this... but no, it was screwed right in... looking at it, i am beginning to wonder if the case / twist grip part is off another bike? the engine kill switch works opposite to how it should as well... anyone any ideas?A.Holley wrote:Damn I pad keyboard,
Andrew
That's not the proper throttle tube, which is why it doesn't stop !
Dam... Looks like I will have to get a new onetitan performance wrote:That's not the proper throttle tube, which is why it doesn't stop !
I took a look at the one I have, and one on the web... and thought I can make that... so I made one out of brass and silver soldered it on the tube. works a treat and feels much better, and has a positive stop.
thanks guys.
thanks guys.
