From those threads the prior problems fixed were hanging throttle due to air being sucked from SRIS lines that were partially connected (WTF? I plugged them), and fouling the left plug which I attribute to the float for that cylinder being way off and the timing not being set correctly. So you might be asking, "how did he fix the float if he didn't remove the carb?" Well, I removed all three as the bundle so I could get to the float bowl of the one.
The bike is certainly running 150% better - no more hanging RPMs or fouling plugs but this brings me to the next problem. The bike surges when cruising or off throttle. It's bad enough that I often have to pull in the clutch to stop the surging on a long downhill for example and am constantly in a cycle of on the throttle and off, awaiting to pull in the clutch when off throttle. Obviously this isn't ideal!
First thing I'm planning to do is to try lowering the clip a notch on the jet needle to richen it in the 1/4-3/4 throttle zone and thus the need to remove each carb. First, does that sound like a good plan of action or would you do something else first to fix the surging? Assuming I should proceed with this, what do I need to know about removing the carbs from the...don't know what you would call it specifically...the hanger plate that the three carbs are connected to? I'm unfamiliar with this style of setup for the carbs and am afraid of screwing something up when disconnecting the top portion where the boots are specifically. Any advice? For example, the little screw at the very top, what specifically does that adjust and how do I get the three back into proper adjustment when reassembling them back onto the bar/plate that holds the three?
Hope that makes sense. I couldn't find any information specifically about removal / reassembly of the carb from the carb hanger plate doohickey. BTW, what is the plate doohickey called?
Any wisdom appreciated before I go really screwing it up. Thanks in advance!!
