Carburetor Help
zl900Love
Country: United States
Suzuki 2-Strokes: 1974 GT550
Carburetor Help
Post by zl900Love »
Ok I got a gt550 a few days ago and the carbs are all balled up can some one tell me if the little ball on the side of the carb can be replace or does it make it in operable?
zl900Love
Re: Carburetor Help
Post by zl900Love »
zl900Love
Re: Carburetor Help
Post by zl900Love »
Re: Carburetor Help
That's how they should be.
zl900Love
Re: Carburetor Help
Post by zl900Love »
With the thing missing out of the hole I don't think so
Re: Carburetor Help
What I meant was that the balls should be there. Never known any ever come out.
What model 550 is it? Are those separate or banked carbs?
GTandcbr
Country: WALES
Re: Carburetor Help
Post by GTandcbr »
Have a read here
viewtopic.php?f=2&t=11705&p=155179&hilit=+Holes#p155179" onclick="window.open(this.href);return false;
(Rip coyote)
98 carb Blackbird and GT550j
Re: Carburetor Help
Some of the holes are cross drillings from the manufacturing process and have balls pressed in to seal them after machining. Others are left open by design.
What we can't determine from the info provided so far is if your carbs have the correct holes plugged or unplugged or if some of the balls have been removed. Carbs on 72/73 bikes are separate and later carbs were joined at the top and are slightly different. I just checked my files and of all the pictures I took of a set of '72 GT550 carbs, unfortunately none show the balls in the intake side, so I can't tell you for sure which should be plugged.
Perhaps if you could take pictures of all 3 carb intakes, perhaps one of the GT550 gurus will chime in.
zl900Love
Re: Carburetor Help
Post by zl900Love »
Ok well if I figure out which one need to be plugged? What should I use to plug them?
