Headlight wanted.
Posted: Sat Aug 20, 2016 3:56 am
by alfiemorris
I'm looking for one that will fit between fork ears, 4 3/4", on my T250. Any recommendations?
Re: Headlight wanted.
Posted: Sat Aug 20, 2016 5:41 am
by ConnerVT
4 3/4"? Is this correct?
5 3/4" and 7" are more standard sizes. Probably can find a patterned part to fit these.
Posted: Sat Aug 20, 2016 6:31 am
The stock T250/T350 flat-bottomed headlight is about the same size as a 5-3/4” headlight.
Posted: Sat Aug 20, 2016 10:56 am
by ConnerVT
There you go.
Emgo 66-65073 - 5 3/4" chrome shell. Standard size light should fit. Just don't go too high wattage, without upgrading electrical system some.
I have the 7" model on my T500. Looks period correct, and have a much brighter headlight now, too.
Posted: Sat Aug 20, 2016 1:37 pm
by alfiemorris
:wth: Just measured again between fork ears 'cos I was doubting myself. Definately measures 4 and 3/4" ? How can this be? I have standard fork ears, bucket bracket and square bottom headlight? Fork ears look ok and not bent out of shape.
Posted: Tue Aug 23, 2016 12:39 am
by alanr
you are after the bucket and ring mount set up(which I have spare.no bulb.).on my 250 l put 350 ears and flat bottom headlight on.l had to trim about an inch off the ears to fit.also have other spares.4 and 3/4 is correct.l also have rechromed 250 ears spare.
