Tank Sealant
Glyn.G
Suzuki 2-Strokes: Suzuki GT380 B- Yamaha FZ1
Tank Sealant
Post by Glyn.G »
Hi,
I know I've seen a thread on the use of POR 15 sealant before but I can't seem to find it again, so I was wondering what method is used. After the cleaning process do I just pour in the sealant and slosh it around.
Any advice will be much appreciated.
Regards,
Glyn.
GTandcbr
Country: WALES
Re: Tank Sealant
Post by GTandcbr »
http://www.por15.com/POR-15-Fuel-Tank-R ... _p_62.html" onclick="window.open(this.href);return false; there you go.
98 carb Blackbird and GT550j
Glyn.G
Re: Tank Sealant
Post by Glyn.G »
Cheers for the info,
I'll get some ordered.
Regards,
Glyn.
Re: Tank Sealant
I've used POR-15 several times with great success. The last one I did, I tried Caswell's sealer which is actually easier, but I can't say whether or not it's better as yet. POR-15 works; that I can say.
Warehouse1001
Re: Tank Sealant
Post by Warehouse1001 »
Never used POR-15, but can attest to the Caswell products durability. Especially with ethanol.
Eddie
Re: Tank Sealant
Post by Eddie »
I sealed the gt750's tank with caswell and its been at least 5 or 6 years now and it always has gas in it,,,not one problem so far and I hope I don't jinx myself by saying that........also its way easier to use than anything I have used and it dries clear. This is just my experience with it, good luck...
tintruder
Re: Tank Sealant
Post by tintruder »
The 3M Product EC-776 works great.
https://www.3m.com/3M/en_US/company-us/ ... 364&rt=rud" onclick="window.open(this.href);return false;
SKA125 (1962)
M15
T10 (2x one with Hyd rear brake)
S32-2 (2x)
T20 (2x)
T200
TC250 (3x)
TC305
T305
T350
T500 (5x)
GT185
GT550
GT750 (2x)
RE5 (3x)
TS50
TC125 (2x)
TS125 (2x)
TS185
TS250 (1970)
TS250 (3x)
TM250
RL250
TS400 (2x)
TM400 (2x)
B-King
joolstacho
Re: Tank Sealant
Post by joolstacho »
tintruder wrote:The 3M Product EC-776 works great.
https://www.3m.com/3M/en_US/company-us/ ... 364&rt=rud" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Well. If you HAVE TO DO IT this 3M product is probably the best one to use. (I think this is the product used to re-seal all our Aussie F15 Hornet fuel tanks with).
Looks like it comes in 1 quart or 5 gallon containers.
Gawd 'elp ya if it ever starts to flake off on the inside... then the nightmare REALLY starts!
Re: Tank Sealant
Not sure what it was, but the sealer on the gt750 tank let go after just on 1000 miles last year. I used proper stripper to get it out, then found out it had been applied over another sealer. It was the first one that had actually been put in incorrectly.
Of course this was after the tank had ben painted fully. I then sent it away to be chemically stripped - twice - and painted again, so folks will understand if I say 'strip and clean the tank properly and don't use tank sealer'. None of my bikes have any in.
Evans Ward
Re: Tank Sealant
Post by Evans Ward »
I've sealed 4 tanks with POR15 with excellent results. You must follow the instructions as indicated and not skip any steps. You need to schedule a good half day or more. Be very careful if your paint is good! You do not want to get any chemicals on the painted surface. I would recommend at least 3 layers of tape over the entire painted surface. The other thing I wouldn't recommend is to leave a heat gun or hair dryer in the top hole for drying the tank out. I actually had one tank's tape catch on fire on the tape and ruin the paint job. It does provide a hard surface once done and I have one tank done 12 years ago still working as intended. It will seal pin holes too. Prior to this process, I fill the tank with Evaporust (great product!!) and let it sit for a week. This step will improve your results. Tip: purchase your Evaporust in the 5 gal bucket off Amazon for about $80 including shipping. Have never used the Caswell product but have heard great reviews from its users.
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
Re: Tank Sealant
Post by johnakay »
if your tank is not leaking then why bother?
joolstacho
Re: Tank Sealant
Yes! Very good question.
(One day sure enough, some poor bugger will have the job of stripping it out!)
Re: Tank Sealant
Evapo-rust & Metal Rescue are both available from Amazon for about $80 for 5 gallons.
My GT380 cafe build had the worst tank rust I’ve ever seen. It wouldn’t start because rust had pretty much completely plugged up the petcock.
Used Caswell + a new petcock.
My gray GT750 was having petcock problems. Happened twice: petcock went bad & then got gas dripping out of a carb.
Finally at the end of this riding season I figured out why. Took the petcock apart & there were tiny bits of tank liner screwing with the diaphragm mechanism. (I used inline fuel filters so the carb were ok.) Some PO had lined the tank so I don’t know what he used.
At least now I know what’s wrong & its on the list of projects for next year.
Evans Ward
Re: Tank Sealant
Most of you probably already know, but that Kreem is some bad stuff especially when the liner starts separating. That one should be avoided at all costs.
