T500 steering head bearing replacement
Posted: Fri Aug 26, 2016 6:11 pm
Greetings all. I don't think I've posted here before because up until now I've gotten the info I've needed successfully from the T500 Facebook group. I've had this BBS in my backpocket since February in case I needed it, and now I do.
I have a 1970 T500 that I'm building into a racebike to race in NH in the US. I started out trying to find replacement traces for my steering head bearings but soon learned that the proper move was to replace them with tapered bearings. My problem now is that I can't figure out what size tapered bearings to fit.
I have done a little data gathering and I've discovered the following things about the steering head bearings in my bike.
1.) The upper and lower bearings are definitely different sizes.
2.) I measured the upper ones and I'm 99% sure they are ID: 27mm and OD: 48mm. I don't have a measurement on the lower ones.
3.) My bike was manufactured in December 1969 and has VIN#T500-25230.
My hope is that with that information someone here can tell me what tapered bearings to buy in order to replace my steering head bearings which, while not completely shot, a significantly pitted and need replacement.
Any help would be MASSIVELY appreciated at this point!!
Peter Booth
Jericho, VT USA
Peter Booth
Jericho, VT USA
