liquid gasket
Posted: Tue Nov 15, 2016 11:29 pm
by dyrberg123
Any recommendations on petrol resistant liquid gasket, what are you using out there?
I use to use yamabond but thats no longer available - then i switched to the silicone type, but found that those aren't petrol resistant, so now i am a bit confused
Re: liquid gasket
Posted: Wed Nov 16, 2016 3:29 am
by Glyn.G
Hi dyrberg123,
I use Threebond 1104 on all my crankcases and any other gaskets that need a little extra help sealing. It is oil and petrol resistant and I've had no problems so far.
Regards,
Glyn.
Re: liquid gasket
Posted: Wed Nov 16, 2016 5:28 am
by rngdng
Yamabond was made by Three bond. There are newer versions than 1104 but Three Bond is still the right stuff.
Re: liquid gasket
Posted: Wed Nov 16, 2016 11:25 pm
by pearljam724
Depends what your intending to seal. Seal All works very well on plastic. Can't speak for using it on metal.
Re: liquid gasket
Posted: Thu Nov 17, 2016 11:01 am
by Warehouse1001
1104 (and its predecessors ) is what I use on all my restorations. Has never failed me. A little goes a long way btw.
Re: liquid gasket
Posted: Thu Nov 17, 2016 11:38 am
by tricky1962
What are you trying to seal?
Re: liquid gasket
Posted: Thu Nov 17, 2016 12:06 pm
by dyrberg123
Hi, pretty important question i suppose.
I am sealing crankcase halfs here. Just ordered som treebond 1104 as suggested, so maybe this will do the trick
Re: liquid gasket
Posted: Thu Nov 17, 2016 3:04 pm
by Zunspec4
+1 with the Threebond 1104. I apply it to the crankcase mating surfaces, one side only, with a small paint brush. As reported, you don't need much.
Re: liquid gasket
Posted: Thu Nov 17, 2016 4:29 pm
by johnu
I just ordered some myself on ebay $12.80
Re: liquid gasket
Posted: Fri Nov 18, 2016 5:01 am
by yeadon_m
+1 on that.
I used it for my most recent crankcase closure (GT550B) and its been fine for its first 500 miles (then the good weather went
Re: liquid gasket
Posted: Fri Nov 18, 2016 10:16 am
by tricky1962
+2 (+3?) for Threebond 1104. 17 000 miles and counting
Re: liquid gasket
Posted: Fri Nov 18, 2016 12:35 pm
by dyrberg123
Seems like i did right.. Pretty expensive in europe though - but who counts
wifes comming...
Re: liquid gasket
Posted: Fri Nov 18, 2016 2:28 pm
by yeadon_m
If you think Threebond is expensive, she's been lying to you about the cost of cosmetics
