T500M rear indicator fixing.
Posted: Wed Dec 14, 2016 7:36 am
Hi,
A question about fixing of the rear indicators on my T500M.
I've seen photos with the indicator fixed directly into the forward threaded hole in the frame, with a nut and bolt through the rubber grommet of the rear hole, holding the seat. I've also seen the indicator stem with a bracket fixed to it, indicator to the rear seat holding hole and bolt through the forward threaded hole. Mine has the bracket, but doesn't fit flush with the 2 mounting points.
Hope that makes sense! Why the 2 different fixing methods?
Thanks.
Thanks.
