Flooding RT cylinder
Posted: Sun Jun 18, 2017 9:34 pm
by ZEP421
73 GT250 Rt side floods upon start up, has been running good. Carbs have been cleaned and all passages are clear, needle valve does not leak, pilot jet, main jet clear..spark seems equal on both sides, 150 compression both cylinders. Is there anything else that would create this issue other than carburetion? Best Wishes Tim
Re: Flooding RT cylinder
Posted: Mon Jun 19, 2017 5:20 am
by rngdng
Choke plunger not closing might cause that.
Posted: Mon Jun 19, 2017 5:35 am
by akendall1966
Had a similar issue, which I believe was due making my own float bowel gasket out of thicker than OEM material. I think this caused the arc of the float travel to touch the side of the float bowel and stop it closing fully. Hard to prove definitively and could be the act of taking it apart again cured something else and going back to stock gaskets was a coincidence.
Posted: Mon Jun 19, 2017 11:24 am
by Goldnrust
I've just been chasing a similar issue with my T500, turned out one of the floats had a crack in it and had partially filled with petrol. So might be worth making sure both your floats float properly
Posted: Mon Jun 19, 2017 5:06 pm
by ZEP421
I'm going to check float level. Anyone know what the measurement should be. Not sure of the exact model ( letter, number combo) On a Mikuni VM34 it's 22-24 MM. Also would a weak spark cause fuel not to ignite? Seem to have equal spark on both sides. Best Wishes
Posted: Mon Jun 19, 2017 5:13 pm
by ZEP421
Goldnrust wrote:I've just been chasing a similar issue with my T500, turned out one of the floats had a crack in it and had partially filled with petrol. So might be worth making sure both your floats float properly
