think I finally got it after 6 month
Posted: Sun Apr 01, 2018 9:36 am
Last summer I was riding my 73 GT750 when it started backfiring and popping through the carbs. Thinking it was ignition I replaced the points, condensers and plugs. After this it worked fine for about 50 miles when it happened again, this time it was so bad I had to pull the left plug wire to get it home. Thinking I may have holed a piston, I did a compression test and found all cylinders around the same. Then I made a vacuum tester to check crank seals, I used a pvc pipe cap and threaded a hose adapter through it connected to a vacuum gauge, removed the carbs and placed the pipe cap in carb boot and cranked over, all three were the same. At this point I was drawing a blank so I pulled off the entire points plate and wire harness to change with a spare, when I noticed a small rub mark where the harness went through a clamp under the motor, apparently firing the plug at the wrong time. Since repairing this it hasn't acted up, but I wont take it far from home till I am sure.
