Page 1 of 2
Suzuki S32
Posted: Tue Jan 28, 2020 2:05 pm
by vintageguy
I'm considering diving into a huge project . Reviving an old S32. Anyone have some pos/neg feedback they can give?
Also what year is frame number with 1203?
Re: Suzuki S32
Posted: Tue Jan 28, 2020 3:28 pm
by Scorch
S32? Pictures? I have not heard of that model. :up:
Welcome to the forum :)
Re: Suzuki S32
Posted: Tue Jan 28, 2020 4:16 pm
by vintageguy
I don't have any now. Do a search on this site. You will see one Maybe do S32-2
Re: Suzuki S32
Posted: Thu Jan 30, 2020 1:42 pm
by sbaugz
I just restored one. On the positive side, they are very simple and easy to work on. The motor is very light and there aren’t many parts. On the negative side, parts are fairly hard to find, and it doesn’t seem very durable. Mine only had 5000 miles on it but nearly all the transmission gears were stripped and the drive hub was cracked. I had to replace a lot of parts.
Look at my thread under the restorations section for details and pics.
Re: Suzuki S32
Posted: Thu Jan 30, 2020 5:24 pm
Best of luck, the older the resto, the harder it gets.
Re: Suzuki S32
Posted: Sat Feb 01, 2020 11:08 am
by vintageguy
Does anyone have a wiring diagram ????
Still trying to find out what year is vin number starting with 1203 ??? Has wide flared front fender
Re: Suzuki S32
Posted: Sat Feb 01, 2020 5:47 pm
OldJapaneseBikes has some VIN info:
http://www.oldjapanesebikes.com/mraxl_G ... /index.php
https://docs.google.com/spreadsheets/d/ ... Ns/pubhtml
SuzukiCyles.org has very little info:
http://www.suzukicycles.org/S-series/S32_specs.shtml
Printed parts & service manuals will be helpful. eBay has a bunch.
This multi-year manual includes parts & service:
https://www.ebay.com/itm/Suzuki-S32-2-p ... Sw2xRYgV4M
Re: Suzuki S32
Posted: Sat Feb 01, 2020 6:09 pm
https://www.cmsnl.com/suzuki-s32-1968-u ... /partslist" onclick="window.open(this.href);return false; might be of use.
Re: Suzuki S32
Posted: Mon Feb 03, 2020 7:17 am
by vintageguy
what other spark plugs can be used beside the NGK B-77C
Re: Suzuki S32
Posted: Fri Feb 21, 2020 3:32 pm
by vintageguy
ANYONE ????????
Re: Suzuki S32
Posted: Fri Feb 21, 2020 5:06 pm
by sbaugz
Accel 123
Autolite 353
Bosch 0241245592
Bosch W5EC
This is what a quick google search came up with. I would recommend going to an auto parts store and they can cross reference. I cannot get to my bike until spring, otherwise I would look and tell you.
Re: Suzuki S32
Posted: Sun Mar 01, 2020 6:18 am
by vintageguy
Is a fully charged 12v battery required to get/check for spark ????
Re: Suzuki S32
Posted: Tue Mar 03, 2020 1:06 pm
by vintageguy
Anyone ???????
Re: Suzuki S32
Posted: Tue Mar 03, 2020 3:18 pm
by Zunspec4
If the ignition is Points & Coil, yes, you will need a battery.
If the ignition is by Flywheel Magneto, no, you will not need a battery.
Re: Suzuki S32
Posted: Thu Mar 05, 2020 9:33 pm
by sbaugz
Zunspec4 wrote:If the ignition is Points & Coil, yes, you will need a battery.
It’s points and coil. Yes you need a charged battery
