T500 battery
casperdog
Country: United Kingdom
Suzuki 2-Strokes: T500
T500 battery
Post by casperdog »
Hi, I need a battery for my T500r, I'm using a standard battery box. The bike came battery-less so before I order the wrong one can any body give me makes and numbers of replacement ones. I'm in the UK if that makes any difference.
Many thanks
Phil.
Zunspec4
Re: T500 battery
Post by Zunspec4 »
Hi there Phil,
This is the battery I had fitted to my T500. They say a picture is worth a thousand words :D
Cheers Geoff
Re: T500 battery
If you still have the stock rectifier & voltage regulator, then you should get a conventional battery with a vent tube.
If you upgrade to a modern rectifier/regulator then you can use an AGM or maintenance-free battery.
casperdog
Re: T500 battery
Post by casperdog »
Hi, just ordered a YUASA YB7A which has the same dimensions as Geoff's post. Thanks for that.
Phil
