Page 1 of 2
No Spark
Posted: Sun Jul 26, 2020 5:16 am
by Monkey man
Hi Guys
I seem to have lost the spark to all plugs on my GT 750J- i was cleaning up the points with the intention of strobing the timing - the bike was running before this. i am also suspicious that the battery was nit charging properly as i had to re-charge it off the bike despite it being on trickle charge when on the bike . i don’t think the two are related but they might be . Anyone got any ideas what’s gone wrong . I have since re-charged the battery and the starter motor turns over strongly but no spark at the plugs .
Re: No Spark
Posted: Sun Jul 26, 2020 5:39 am
by GTandcbr
Hi
Have you cleaned the points in the old way with some kind of emery paper? Modern points have a plated surface which you clean with just a plain bit of white cardboard. Any abrasive material will stop the points working.
Re: No Spark
Posted: Sun Jul 26, 2020 8:30 am
If you removed the points to clean them, you may have assembled the parts in the wrong order. See:
PointDiagram1 by
jabcb, on Flickr
Re: No Spark
Posted: Sun Jul 26, 2020 8:39 am
by Monkey man
yes i used emery paper - are they retrievable if i clean with something else ?
Re: No Spark
Posted: Sun Jul 26, 2020 10:30 am
by GTandcbr
Sorry nope. They are toast i'm afraid
Re: No Spark
Posted: Sun Jul 26, 2020 2:40 pm
by Monkey man
Looking at the web - they don’t come cheap - and there are some different makes out there - any recommendations and are the three sets all the same or do they have different part numbers ?
Re: No Spark
Posted: Sun Jul 26, 2020 11:41 pm
by GTandcbr
Look here
https://www.suzytwo.co.uk/shop/search.p ... ton=Search" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
And hete
https://www.robinsonsfoundry.co.uk/shop ... 2_1977.htm" onclick="window.open(this.href);return false;
Re: No Spark
Posted: Mon Jul 27, 2020 3:18 am
The price of 3 new OEM points & condensers is in the same ballpark as an electronic ignition.
Accent has the easiest to install electronic ignition. It was 155 Euro + shipping for the GT550 version.
http://www.accent-electronic.com/ELZ2Coil.html
Their website doesn’t provide much info. But they are easy to deal with via email & can converse in English.
email:
uwe.gottwald@accent-electronic.com
Re: No Spark
Posted: Mon Jul 27, 2020 10:02 am
by Monkey man
Or is it time to bite the bullet and go for electronic ignition ?
Re: No Spark
Posted: Mon Jul 27, 2020 10:18 am
This is the Accent ignition on my GT550. There is no external controller box. It has an LED that you use to set the timing. So its pretty easy to install.
cafe-GT550-1233 by
jabcb, on Flickr
Re: No Spark
Posted: Mon Jul 27, 2020 2:40 pm
by Monkey man
Thanks everyone for the info - there’s a big difference in price for the contact points from Robinson’s and those from suzytwo.
I’ve emailed Accent and await there reply . Has anyone fitted a system from Newtronic ?
Re: No Spark
Posted: Mon Jul 27, 2020 3:52 pm
by daxman
GTandcbr wrote:Hi
How do you know if you have these 'modern' points? I've never heard of this plating before, although admittedly I haven't had my GT that long..
Points mostly went away by early 80s so did they start to make replacements to OE with this surface?
Re: No Spark
Posted: Mon Jul 27, 2020 5:44 pm
My two GT750s have Newtronic ignition. A good option. They have a small controller box that you have to mount.
Years ago there some some online negative comments about them. But the products were improved after Autocar aqcuired the company.
Re: No Spark
Posted: Tue Jul 28, 2020 12:02 am
by GTandcbr
daxman wrote:GTandcbr wrote:Hi
Modern points have a tungsten plate. If cleaned with emery paper the tiny particles left on the surface burn and damage the surface. Also when you remove the tungsten down to steel that will rust causing no contact.
Re: No Spark
Posted: Tue Jul 28, 2020 2:12 pm
by Craig380
Daichi-branded pattern points are fine, I used them on my 380. Much cheaper than OEM.
