Wanted GT750 Oil Lines
jb56
Suzuki 2-Strokes: GT750
Post by jb56 »
Wanted oil lines for my GT750 L the ones that go from the pump to the crankcases
Re: Wanted GT750 Oil Lines
Hi,did you see the UK Ebay auction for the new/old stock oil lines ? The Auction has just ended,went for a staggering £250 ! Second hand ones on Ebay from time to time,the problem being that with age the lines tend to have valve issues...stick open & allow oil to seep into the crank cases when the bikes not running...a fair bit has been written about it here on this forum & elsewhere.Just recently "posted" on here someone in the UK is about to start selling a repair kit to fix this problem....but things have gone a bit "quite",as to when this will happen!! please see previous posts on the subject "re manufactured check valves". :roll:
jb56 wrote:Wanted oil lines for my GT750 L the ones that go from the pump to the crankcases
Are your current ones missing, or damaged in some way ? If they are just passing by, then as per the previous post there is a lot of material on this board on how to flush the check valves which very often solves leakage problems. Just make sure you do not use compressed air to blow them out. If you have already flushed them out and they are still passing by, then your options are limited. 8)
