aftermarket master cylinder sugestions for gt750
Posted: Thu Apr 03, 2014 5:02 am
by two-stroke-brit
hi all.
were my buffalo has been sitting dormant for 18 months the master cylinder has leaked, not sure if its just the seal because it looks like it came from under the clear plastic cup bit.
so was thinking of replacing with an aftermarket one but need to know the dia to maintain the same feel.
any pointers or recommendations are most appreciated
thanks mark
Re: aftermarket master cylinder sugestions for gt750
Posted: Thu Apr 03, 2014 6:43 am
This article on front master cylinder ratio is worth a read.
http://www.vintagebrake.com/mastercylinder.htm
Posted: Thu Apr 03, 2014 7:18 am
by Coyote
Doesn't anybody look at my sticky post "general info and specs"? The info on the MC specs is in there. Just look!
Posted: Thu Apr 03, 2014 8:21 am
by two-stroke-brit
thanks coyote i did a search for gt750 m/c and all i found was a couple of threads on a gt550 upgrade.
i need more practice with the "search is your friend button"
thanks mark
Posted: Thu Apr 03, 2014 10:52 am
by Craig380
I fitted a M/C from an RF900 (same type as fitted to all the twin-disc Bandits) to my 380 with single disc, it works a treat. Stopping is a now 2-finger job rather than the 2-fist job it used to be :shock:, but it's also progressive with good feel and never 'grabs.' All-metal one-piece body too, so no leaks.
Of course the new M/C is overpowering the single caliper but it should work fine with the two-caliper setup on the GT750.
Posted: Thu Apr 03, 2014 11:30 am
by two-stroke-brit
thanks everyone :up:
