Its a 500 Jim, but not as we know it !
Re: Its a 500 Jim, but not as we know it !
Got the little blighter fired up today, sounds nice. No tank, it's got a rather pronounced leak.
http://www.flickr.com/photos/zunspec/64 ... hotostream
Cheers Zunspec
Cheers Zunspec
- greasemonkey
- Country: Belgium
- Suzuki 2-Strokes: Gt500
very nice sounding machine
- kettle kid
- Suzuki 2-Strokes: GT380A GT750L GT750J Z900
Thanks chaps, appreciated.
As for doing it for a living....I don't think so, there is a big difference between goofing around in the workshop and having to make a crust doing it
The next project pipe dream is re-creating the Seeley TR500 I used to have. Anyone got a set of straight cut Primary gears and a C/R gearbox
Cheers Zunspec
Cheers Zunspec
I know you canI can supply all you need for the Seeley Rep
I'm thinking:
Lightened Crank
Crank re-build with parts as necessary (I have NOS Rods and a Centre bearing)
C/Case stuffers (although I'm not up on modern theory regarding these)
C/R G/Box + new bearings
Would love a Dry Clutch, but standard would suffice
Straight cut Primary gears
Centre plug heads (my original Seeley had "works" items, or so I was informed
Barrels ported (what Spec TBD)
C/Case matched to ported barrels
Self generating ignition & Tacho (original used a Krober set up)
Cut back the sprocket cover as necessary
Retain CCI lubrication (with mods)
Pistons ? I used to use GT750 items with 1mm cut off the skirts and cut aways matched to the barrel
A set of proper racing Carbs (original used 38mm Mikunis)
Pipes ? dependant upon state of tune I suppose
Now for the chassis:
Seeley frame (I wonder where I could get one of those?)
Forks, Road Holders and a single Lockheed disc setup was very effective but there's better out there now. Something from a suitable road bike maybe.
Spoked Aluminium wheels if possible
Aluminium tank and suitable seat unit (I junked my original Seeley item and helped a mate make a mould and turned out our own (His went on a Ducati GT750 bevel case)
TZ 250/350 fairing, or something more modern?
Some sticky rubber
Daytime MOT
Pop, dream over
Cheers Geoff
A vid of the bike in the fresh air:
I gave it a spin up the road and back, now I have a dozen things to adjust
Cheers Zunspec
Cheers Zunspec
Looks and sounds good.
Terry
From what you started with April 2010 the results are just amazing .. fantastic work
Thanks suzukidave.
It has taken a while but that's normal for my projects
I now have to wait until spring and the road salt to disappear before getting it on the road.
Cheers Zunspec
Cheers Zunspec
Well the Triumph is 99.99% finished, apart from the engine strip-down to try and address the oil leaks
. Came up quite nice from what it was.
What can I do next I wonder.
Cheers Zunspec
Cheers Zunspec
I repeat myself .. fantastic work
.. not to change the subject but whats lurking behind your project with the white SSSA rear wheel .. a VFR400 maybe ?
Hello Suzukidave,
The Triumph has turned out well but I now enter the actually running it on the road phase. I have already mentally prepared myself to have to address oil leaks, of which there are plenty
I actually have 2 VFR400Rs (NC30), both were road legal and running but would require a few months recommissioning now. It's damn hard work to keep everything running
. They are a jewel of engineering, good for 125+ mph when running to spec.
Cheers Geoff
Cheers Geoff
Very nice 2 VFR400s
in a earlier post you say what you should tackle next , well with such talent i would enjoy seeing you put together something custom like a TR750 .
Well, I have this GT500 sitting in the shed, would make a nice doner bike for a Seeley (replica) framed TR500
