GT750B First Start after 26 years - success!
RING_DING
Suzuki 2-Strokes: 1974 GT750 B-4 (JDM), 1975 GT750M
Post by RING_DING »
I am delighted to be able to share this with you all:
http://www.youtube.com/watch?v=b4pFcx9dukw" onclick="window.open(this.href);return false;
The rattling you hear is the oil pump cover which I did not bolt down as I wanted to see the oil lines.
It runs on choke but dies as soon as choke is off. Still more work to be done, but this a major milestone.
Engine sounds great....no weird knocking sounds or anything.
Cliff
Re: GT750B First Start after 26 years - success!
Post by Cliff »
Isn't that a GREAT feeling when she fires up for the first time!!
Scorch
Born to ride
Suzuki 2-Strokes: 1975 GT380
Post by Scorch »
Excellent video, thanks for sharing :up: That's what I like about these type of communities, very cool.
two-stroke-brit
Suzuki 2-Strokes: gt750
Post by two-stroke-brit »
Congratualtions the smile on your face says it all.
you dont sound like a NC native.
thats what i like about these utube clips ,you get to put faces and voices to the screen names.
dont forget to post as you go.
cheers mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
RING_DING
Post by RING_DING »
Mark, you are right I am not native to NC. I'm 100% purebred Oirish. I guess I still have a bit of the oul' brogue left!
two-stroke-brit
RING_DING wrote:Mark, you are right I am not native to NC. I'm 100% purebred Oirish. I guess I still have a bit of the oul' brogue left!
You certainly do , what colour is the buffalo and looks like you will be ready for the gap next year ?.
cheers mark
1985 RZ350N
Nice one !!! :up: :up: :up:
mick 63
Country: Great Britain.
Suzuki 2-Strokes: Suzuki GT750 A 1976.
Post by mick 63 »
Another one saved :up: i can understand your excitement 8) good luck with the rest of your resto :wink: , cheers Mick.
Roy did you clean out those carbs? the mixture circuit on each carb has a long torturous route from the air jet in the bell mouth through the carb bowl and up to the mixture screw.
The bike wont idle if they have issues and especially if the carbs have been sitting for a long time, they are a PITA to get properly cleaned of the residue.
RING_DING
Post by RING_DING »
Allan I did give them a good clean out. I read Pink Possum's article on carb cleaning which helped me understand the "tortuous path". The one thing I did not do was remove and clean the pilot jets. I tried to remove one and I stripped the head so I left them alone, and just blew carb cleaner through them. Now I think they will be my first suspect for the non-idling. I found a few tips here on the forum for removing the stripped jet and I have new ones on order.
I do have a question about float height though. Ian pointed me to a You Tube video by Hispekk:
http://www.youtube.com/watch?v=Cukul7TqLsE" onclick="window.open(this.href);return false;
where he says you measure the height with the gasket in place.
The shop manual (and Haynes I think) do not mention measuring with gasket in. Which is correct?
I didnt follow either route Roy but raised my float levels about 2mms more. I found it helped the minor remaining surging issue I had, and this is AFTER I did the jet mod in the bellmouth.
So you need to get those pilot jets out of there as thats where your problem lies for sure.
The shop manual is the route to go for measuring the float height but thats for a stock setup which I strayed away from.
Make sure your gaskets are the 'flippable' ones, as some types cover the hole for the pilot circuit if put in the other way.
When you order a new set of pilot jets take the time to be 110% sure you have the right ones. The wrong ones will cause all manner f problems but they look the same to a casual observer.
Here you go, the Sudco page for the BS pilot jets, and yes its big for a reason.
RING_DING
Post by RING_DING »
Thanks to all for your very helpful replies. I removed the stripped pilot jet by drilling it out and using an easy-out (no heat needed, just a sharp twist). The other two unscrewed readily enough. Sure enough they were all blocked solid. I fitted three new #45 pilots and after sorting out which way round the bowl gasket goes (see my other post...thanks again TZ!) refitted the carbs today. She fired up first time on choke, and then idled away without choke after about 45 seconds. Brilliant!
On to the next phase of the project which will be forks, brakes & tires.
two-stroke-brit
hey ring ding i upgraded the fork springs with the progressive springs and was pleased with the results. :)
good luck mark
1985 RZ350N
