T500 - Gearbox Dam Retrofit - Glue and/or Sealant?
Posted: Thu Nov 29, 2012 3:08 am
by Syd
Is there are recommended glue or sealant that you should use to hold the rubber dam in place that you fit into the gearbox on a 72 Suzuki T500 when doing this modification?
Re: T500 - Gearbox Dam Retrofit - Glue and/or Sealant?
Posted: Sat Dec 01, 2012 8:02 am
by LexPaul
Syd wrote:Is there are recommended glue or sealant that you should use to hold the rubber dam in place that you fit into the gearbox on a 72 Suzuki T500 when doing this modification?
I just did same mod and used the yamalube, my mechanic swears by it. Good luck and Ride Hard
Posted: Sat Dec 01, 2012 8:09 am
by LexPaul
Oops, I meant, we used the YamaBond, thanks
Posted: Wed Dec 19, 2012 9:16 pm
by Syd
Do you need to remove the complete kick start assy from the case to fit the rubber dam in place or can this be just pushed into place? If you have to remove the kick start assy, is this simple to refit and re tension the spring? Any tips would be appreciated.
