I am currently in the planning of a GT750 with a USD GSX-R fork and a Katana 750 swingarm. I have it here and though it is steel it is really light. And the fact it is steel also makes it easier to modify. Check Rassie's page, he has done it and made sort of easy step by step Photo session of it. He is using Wheels from a GSX-R, but judging from the Pictures it doesn't look much wider than std swingarm. As said i have one here so if you want any meassures let me know
It seems if you post now with a picture attached you have to use the IMG in the box above the section you type in . You may need to reduce the size of you picture a bit ?
here is some pics of my basic GS1000 swingarm and 1200 Bandit foot controls. Very little effort to get this sorted out. I think it's gonna work just fine. Not bad for $140 from the salvage yard.
And by the way folks, THANK YOU for the photo bucket suggestion to post pics!!!!!
Buffalo-guy wrote:A GS swingarm is a common enough transformation, but they are wider, and the stock exhaust won't clear. Try finding a GT 550 arm. They are about 1 1/2" longer, and will bolt right in, and every thing will bolt to it, with little or no mods. Worth a shot. Cheers.
Fred
G'day Fred,
Do you know if the GT 550 rear brake cable is also longer than the GT 750 cable?
Bob.
