Moderators: oldjapanesebikes , H2RICK , Suzsmokeyallan
Posts: 6213 Joined: Mon Nov 03, 2008 10:47 am
Post
by tz375 » Sat Dec 03, 2016 11:51 pm
D&D CHASSIS wrote: Do the Gt750 and t500'see share "similar porting specs?
Very similar depends a lot on which year of either is being compared. The odd thing is that later T500s seem to have porting like an early 750 and later 750s are like an early 500
750 rods are 125mm ctr to ctr IIRC and I was told that T500 are 135mm. Can anyone confirm that? I have used 750 rods I can measure again if needed.
old racer
Posts: 240 Joined: Mon Mar 05, 2012 1:22 pm
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Post
by old racer » Fri Dec 09, 2016 9:10 am
I have just measured both 500 and 750 rods center to center.
750 rod.130mm.
500 rod.134mm.
D&D CHASSIS
Posts: 81 Joined: Fri Jun 19, 2009 8:06 pm
Country: usa
Suzuki 2-Strokes: GT750 dragbike
Post
by D&D CHASSIS » Fri Dec 09, 2016 7:31 pm
Both are the same bore and stroke?
Post
by tz375 » Fri Dec 09, 2016 7:56 pm
I just measured a few used GT750 rods and can confirm that they are 130mm. Well they measured out to 129.98 but that's close enough I guess.
Dave: yes the same bore and stroke.
Jimroid
Posts: 309 Joined: Sun Feb 21, 2016 8:32 pm
Post
by Jimroid » Fri Dec 09, 2016 7:58 pm
Same left/right pistons.
Jimroid
Post
by Jimroid » Mon Jan 02, 2017 5:33 pm
Holidays are over and married off my daughter, so it's time to get building a set of twin pipes. The single carb is staying though.
Posts: 3980 Joined: Fri Oct 24, 2008 5:55 pm
Post
by Suzukidave » Mon Jan 02, 2017 6:24 pm
I dont recall what you have feeding the 500cc engine 40mm at least i would think ?
Jimroid
Post
by Jimroid » Mon Jan 02, 2017 7:36 pm
41mm flatslide. Pics on page 1.
Jimroid
Post
by Jimroid » Wed Jan 11, 2017 4:46 am
Tapered headpipes.I have never seen it done this way! But it works. I drew it together progressively starting at the small gap-with three hose clamps and welded about 1" increments,then moved the clamps down each time.
Zunspec4
Posts: 1087 Joined: Tue Dec 16, 2008 11:37 am
Post
by Zunspec4 » Wed Jan 11, 2017 7:41 am
Nice work, Jim
johnu
Posts: 156 Joined: Thu Sep 29, 2016 4:53 pm
Country: United States
Post
by johnu » Wed Jan 11, 2017 8:46 am
Jim do you have pics with it tacked together?
dgoodsy
Posts: 119 Joined: Wed May 11, 2016 9:44 am
Suzuki 2-Strokes: '72 gt750
Post
by dgoodsy » Wed Jan 11, 2017 9:32 am
Very cool, I would also be interested in pics of the tacs and welding. How do you intend to use the tapered u-shaped pipes now, pie cuts?
'72 GT750
Jimroid
Post
by Jimroid » Wed Jan 11, 2017 9:10 pm
I did not take any pictures of welding the seam or of the spigot install.I need to take the 2 into 1 pipe off,bolt up the headpipes and start fitment. It will be a while as I have a full schedule the next bunch of days.
smokin_blue
Posts: 130 Joined: Fri Nov 01, 2013 8:30 pm
Country: usa
Suzuki 2-Strokes: www.street-unique.com
Post
by smokin_blue » Sun Jan 29, 2017 8:17 pm
Very nice approach. What did you cut the sliver with? Was it a thin cut off wheel on a die grinder?
'07 Suzuki SV650
'90 GSX-R1100 streetfighter
'72 T500 with a Lyster frame
'69 T500-parts/project?
'83 GR650-project
Past bikes
'06 Triumph Sprint ST
'86 GSX-R750
'74 GT250/T350 custom
'79 GS750
'74 TS250
'81 TS100
Jimroid
Post
by Jimroid » Mon Jan 30, 2017 7:20 am
About 5 minutes with a jig saw.
