V4 RGV500
garry55
V4 RGV500
Post by garry55 »
as you may have noticed, progress has been halted on the XR11/73 project as I am now making a determined effort to get my V4 RGV project up and running. We completed the motor build on Friday and have now got it fitted back into the chassis.
On with sorting the wiring now, whilst I await delivery of new throttle cables, water pump kit, plugs and caps. The carbs are away being cleaned and re-jetted to suit and the fuel tank is away being modded to take twin fuel taps. The "temporary" exhausts have been blasted and painted and are ready to fit. Hopefully it will all come together by the time I return from vacation in mid-July. Who knows - it may even work! :D
Garry
garry55
Re: V4 RGV500
Post by garry55 »
final coats of bbq paint applied to the exhausts, as its a nice day for spraying......
and started to trial-fit the electric water pump.......
Garry
garry55
Re: V4 RGV500
Post by garry55 »
in the beginning..................
http://www.rgv250.co.uk/forums/index.ph ... rgv/page-1" onclick="window.open(this.href);return false;
Garry
Re: V4 RGV500
You have very interesting projects Gerry :up:
garry55
Re: V4 RGV500
Post by garry55 »
a bit more tinkering - fitting the 2 stroke oil tank
the machined rotor (on the left, standard RGV rotor on the right for comparison) that came off an Aprilia RS250 race engine
and a couple of gratuitous pics after I removed the radiator (gone for welding)
Garry
jeff kushner
Suzuki 2-Strokes: none
Re: V4 RGV500
Post by jeff kushner »
That is a SWEET project Garry. Where did you get the V4 engine? That isn't just a bored out 250 is it?
That water pump looks very familiar to me....I grew up with boats and it looks like a bilge pump....should give you lots of GPM's though.
jeff
Re: V4 RGV500
It looks like a pair of RGV250 or Aprilia RS250 motors snuggled up together which is hardly a trivial task. The water pump looks like Davis Craig from the land downunder. That's what's going on my next GT750 project.
garry55
Re: V4 RGV500
Post by garry55 »
the motor is 2 RGV250's joined togethr to make a V4.
the water pump kit came from here
http://www.bdkraceeng.co.uk/Electric%20 ... p%201.html" onclick="window.open(this.href);return false;
its not cheap, but does have programmable upper and lower temperature settings which increase / decrease flow proportionally.
Garry
garry55
Re: V4 RGV500
Post by garry55 »
its starting to get serious now - new plugs, plug caps, 12 exhaust gaskets and a fine selection of coolant hoses to try..........
just had time to fit all the plugs and top plug caps before work..........
more hoses to collect tomorrow so may be able to plumb it all in this week. :D
Garry
garry55
Re: V4 RGV500
Post by garry55 »
this can only mean 1 thing...............
well, 2, actually............
nope - make that 3...............
ok - 4 it is...........
Garry
garry55
Re: V4 RGV500
Post by garry55 »
the top 2 ................
and the bottom 2 ................
Garry
garry55
Re: V4 RGV500
Post by garry55 »
hmmmmmm - something missing ?
ahhh - thats better :clap:
Garry
ja-moo
Re: V4 RGV500
Post by ja-moo »
That will be a total blast! :clap: :up: :clap:
Re: V4 RGV500
What a cool project Gerry and a one of a kind :up: it is something to have the only one in the world . What silencers are those as i like the mounts instead of being slipons and then clamped .
garry55
Re: V4 RGV500
Post by garry55 »
they are cheapie-Chinese ones off ebay - bought for testing purposes only (as are the pipes) - they will all be replaced with pukka gear if / when its proven to work. I have been warned not to run the motor for too long with these fitted as the baffle tube is only 20mm diameter. Have to agree - the flanged mounting is vastly superior to the usual "slip-on" method.
Garry
