I've have an almost compleete RT kit for it which should result in something close to 10.5hp at 12000rpm.
Modifications will focus on removing weight and upgrading the front brake to either a bigger drum or a disk brake.
In the picture you can se the bead blasted and primed frame together with the expansion chamber, cyllinder with head and the clucth cover that alows for a 20mm carburator instead of the original 16mm.
I'm missing the disc valve from the kit, but if I can get the timing for it I will just cut an original one to the same spec. Apart from cleaning up the ports a bit the engine will receive an electronic ignition.
Any input on the project is apreciated.
