Anyone have a battery eliminator installed on your bike ?
Posted: Wed May 07, 2014 10:17 am
If so. Let's see some feedback and what item you may have purchased. Perhaps, considering one.
Board
http://suzuki2strokes.com/forum/
Then why advertise this ? http://www.ebay.com/itm/Bat-Pac-BATTERY ... 05&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;jabcb wrote:You can't use a battery eliminator on any of the triples unless you switch to a permanent magnet alternator.
TESTED ON THE FOLLOWING
If your unsure if the Bat-Pac will work for your application please contact me
Yamaha - RD400E,F, and G from the UK. ; RD400F, and G from Canada ; RD350LC 1980-82 ;
RZ350 ; RZ500 ; TZR250 ; XT250 ; XT500 ; XT600 ; TT600 ; TT600r ; SRX600 ; SR500 ; YSR50 ; DT Enduro's ; DT175 ; DT400 ; FZ ; FZR
Suzuki - RG250 ; RG500 ; RGV250 ; GS ; GT185 ; GT250 ; GT500 ; TC90 ; TC120 ; TS250 R,J, & K ;
TS350 ; TM400 ; T125 ; T250 ; T350 ; T500
Honda - MB5 ; Passport C50 C70 C90 ; XR ; (some CB350, CB500) ; CBR600 F1, F2, F3's ;
CL ; CS ; CM - CM125 CM200 CM250 Z50 ;
Kawasaki = KZ ; GPZ ; ZX ; KLR 250
Polaris - 400 Sport ; Scrambler 400 4X4
Vincent - Black Shadow
BSA - ALL Magneto equipped models
Norton - ALL Magneto equipped models
Triumph - ALL Magneto equipped models
Harley Davidson - ALL Magneto equipped models
XR
Compatibility issues:
In general, if it has a permanent magnet flywheel, chances are the Bat-Pac will work.
Older bikes that have a point type magneto can also use the Bat-Pac.
The Bat-Pac works on all that have a magneto CDI/ stator alternator systems. If it uses a
brush type generator/alternator to power the ignition then the Bat-Pac won't work.
The reason for this is because the permanent magnets can induct enough current
in the stator coils to start the engine, whereas brush type charging systems require
a current source with several amps of current capacity to magnetize the windings of the rotor,
and the primary windings of the ignition coils.
The Bat-Pac is compatible with 6 and 12 volt systems, positive or negative ground.
The Bat-Pac can be used along with a battery for improved voltage output of the charging system .
Testing a Bat-Pac on a non-compatible charging system will not damage anything
