GT185 ignition coil issues
Posted: Sun Apr 14, 2013 5:11 pm
by carsonwcram
The right coil works fine, great spark, fires in time. the left coil is a bust, and i thought it was the coil, so i swapped it with one i knew that worked, and still no spark.
But here's the weird part, I'm getting a reading right around 12 volts on my multimeter at the plug boot, but no spark. What could cause this? I"m thinking that the wiring is shorted somewhere and it grounds out under load maybe?
I haven't gone through and chased the wire yet, i was kind of hoping someone would give me an easier solution before i starting slicing open heat shrink.
Re: GT185 ignition coil issues
Posted: Sun Apr 14, 2013 6:31 pm
The GT185 wiring diagram is here: download/file.php?id=827
No need to cut any heat shink.
At the coil to wiring harness connector, check the voltage for both wires for each coil. Do this with the points open & closed.
(A metal paper clip or stand of wire wrapped around the multimeter probe may make it easier to get the readings.)
Check the voltage at the points (on the moveable point) with the points open & closed.
A comparison of the good & bad sides should give you some idea where the problem is.
Also could check the coil primary & secondary resistance just to make sure the good coil is actually good.
Posted: Wed Apr 17, 2013 5:09 am
by carsonwcram
I found the problem, the plastic? plate that kind holds everything together between the points plate and the actual magneto cracked and split, which led to all types of mayhem. brushes breaking, wires rubbing and melting. Just a whole bunch of destruction. I could rebuild it, but i have a parts bike with a good one but bad brushes so i just went ahead and found a decently cheap stator on ebay.
I should be rolling smooth soon. Pictures to come.
