Having an issue and cannot seem to find a wiring diagram for a 1975 RV125, others do not entirely match....
Issue: Blows headlights, pilot light, taillight (not brake, powered by battery I assume) - over 6v delivered when revved
I have a rectifier (new), resister (condition unknown), and no regulator.... I also have a un-terminated Yellow/Red wire, Green/White under the seat.
Safe to assume I need a regulator and that it plugs into Yr & Gw under the seat, even though I cant seem to place one in the wiring diagrams I have seen?
I stumped as to why I am even getting current to blow the bulbs without a regulator being present to complete the circuit? ( under the seat the Gw has a male and female bullet connector splice which I have joined together, perhaps this is completing the circuit and I am delivering unregulated current directly to the bulbs?)
Any help appreciated, much thanks
Blowing Headlights
- Ben
- Suzuki 2-Strokes: 1 too few
Blowing Headlights
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
Re: Blowing Headlights
Hi Ben,
I have a 1978 TS125C which also has direct lighting a.c.(6v bulbs). These have also blown and I have been told that you need a good battery, receiving it's crudely rectified charge (half wave) to stabilise the a.c somewhat. My problem raised itself when my 6v battery became a bit dodgy (through lack of use I think) so there might be some credibility to this theory.
Cheers Geoff
Cheers Geoff
The wiring diagram for the 77 RV125 is here: viewtopic.php?f=29&t=4743&start=10
The wiring diagram shows an AC voltage regulator.
It shows the regulator connecting to a B/W wire -- this looks to be typo in that the wire is also labeled Gr.
Paul Miller lists NOS Suzuki regulator on eBay for $79: http://www.ebay.com/itm/Suzuki-RV90-RV1 ... 0874289219
Would expect a new aftermarket 6V AC voltage regulator to be better than the old NOS part, but its not easy to find it.
Looks like Rex Caunt has one for about $40
http://rexcauntracing.com/pages/regulators.html
http://www.ebay.com/itm/YAMAHA-XT500-DT ... 0165796372
- Ben
I have current under the seat Green/white that is delivering unregulated current, 10v to 30v depending on rpm.
I'm not electronically inclined but building my own regulator sounds like cheap fun.
Of the tutorials I have found, reference is made to the regulator delivering up 7.1v and some number of amps. No mention of watts. I thin my headlight, pilot light, taillight and guage backlight all come from this source. Headlight is 6v 25w/25w .....any tips on how to calculate amps required?
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
The max depends on the alternator performance output curves.
Examples for the triples are shown on page 18 of: http://www.ozebook.com/compendium/suzi/suzidata1.htm
The curves shown are for a 14V (DC measured after the rectifier).
Alternators have a maximum output for a given voltage.
You could do some testing to estimate the curve for a voltage that is safe for your headlight.
Alternatively, if you total up the watts of load that should give some insight.
Normal load is just the headlight + taillight + speedo light + battery charging.
(The magneto is separate & not part of the alternator load.)
There are two design considerations:
1) the electrical components must meet the voltage & current requirements
2) the regulator coverts the excess power to heat & you need a heat sink to prevent overheating of the electrical components
Considering how expensive & hard to find the headlight is, I would be inclined to just use the
Rex Caunt or Suzuki NOS regulator.
- Ben
jabcb., appreciate the help. I have looked over a lot of wiring diagrams and I still cant make sense of it.
the only wiring diagram I have seen that comes close to what my bike is, is the RV125B, but its not entirely consistent and some of the icons I cannot decipher (RV125B Wiring Diagram).
Anyways, I have a
Y/R female open end = from lighting coil
G/W female = from charging coil
G/W male = ?? to/from ??
G female = ?? to/from ??
If you follow the Yr in the wiring diagram link above it turns into Gr (gray) then B/W which goes to the regulator....strange
And I cant decipher the G/W circuit either....
Anyone with a 1975 that can confirm whats what?
Anyways, I have a
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
- ConnerVT
- Novice racer
It is a resistor.
RESISTOR ASSY, MAGNETO K,L
36500-27690
http://www.suzukipartshouse.com/oempart ... 54/magneto
36500-27690
For the 77 RV125B wiring diagram:
The regulator wire that starts out Gr (gray) & switches to B/W should be typo. I would expect it to be Gr & not B/W.
If you look closely at the NOS regulator that Paul Miller has on eBay, it has two wires: a gray wire & a black wire with the grounding connector.
The resistor in your pic is shown in the RV125B diagram as connected to Y/W & G/W wires.
The G/W wire goes to the ignition switch & then isn't used for anything.
I may have found a wiring diagram for an earlier RV125 in this tread on another forum:
http://www.2strokeworld.com/forum/index ... ic=20322.0
The diagram is:
Looks to be a gray scale scan of a color diagram, which makes it harder to use.
The earlier diagram shows a different ignition switch & no voltage regulator.
It shows that the resistor is used as a substitute load when the lights are off.
Would seem reasonable that the early RV125 did not have a voltage regulator & the later models did.
That is what Suzuki did on the GT250.
Since the two diagrams are quite a bit different, you should definitely consider getting a RV125 shop manual that covers your model year. Check eBay.
I would also get an aftermarket AC regulator & mount it so that the frame (or something else) acts as a heat sink.
These mixed AC/DC wiring diagrams are certainly more confusing.
Looks like it confused the Suzuki engineers to the point that they included the resistor on the RV125B even though it is never used.
The diagram is:
