What carbs for a buffalo
Lane, That's a novel solution that I had not worked through yet. Thanks for the tip.
All my 34,36 and 38mm carbs have 42/43mm OD outlets which is way smaller than stock BS40's
Arne wrote:
rngdng wrote:
Also notice on the first pic that I copied the vacuum port from the CV carb, and epoxied it in place. I made the hol in the carb the same size as the original vacuum port . It works great, and they've been this way for about 3 years.
Do you ever have any fuel delivery problems? I've heard the vaccuum diaphragms don't pump as much as open petcocks, but was going to run them on mine anyway...
Arne
Only if you have an early production 1974. There's a service bulletin about the problem.
Many people believe and claim that their bike sucks more gas than the petcock can provide. I thinik most of them are dreaming. If that were a problem, I'd just put in the largest float valve. The vacuum petcock is fine IMO.
