Hi Guys
i have recently acquired a T500m and going thru a learning curve with it . I have just changed the oil and retightened the shift cam guide bolt/neutral detent bolt / oil drain plug and the sludge trap bolt. The detent and guide bolt have been tightened to 12 ft lb / the oil plug to 10 ft lb and the sludge trap (10mm ??) to 7 ft lb.
Has anyone got any actual values or do they feel these are about correct.
Genuine suzuki crush washers used on each
any advice welcome.
regards
paul
T500m torque values
- Country: uk
- Suzuki 2-Strokes: 1975 T500m
T500m torque values
Current bikes:
Suzuki T500m
Honda CB750K 6
Suzuki XT 1000 vstrom
Suzuki T500m
Honda CB750K 6
Re: T500m torque values
Welcome to the forum.
Old Japanese Bikes has the T500 manuals & specs:
https://www.oldjapanesebikes.com/mraxl_ ... /index.php
Muzza has the service bulletins:
http://www.ozebook.com/compendium/techbuls/index.htm
Torque specs are listed in Service Bulletin Specification-3:
http://www.ozebook.com/compendium/techb ... %201-5.pdf
- Country: uk
Thanks for the welcome
, after a life of four strokes, pleased to be in possession of such a great icon (T500).
I am a novice diy mechanic so having a feel for’ torque settings’ is not quite honed yet. I have looked over the info sent and yes the detent and trans oil plug do indeed seem to indicate 12 &10 ft lbs respectively. It then seems to indicate that a10mm bolt which is smaller than the 14&12mm bolts for the detent and oil plug should be tightened up to 13-20 ft lbs from memory ( sludge trap bolt).
I just find it a little confusing hence my reach out to those that know more on the tech side .
Good interesting forum though
Current bikes:
Suzuki T500m
Honda CB750K 6
Suzuki T500m
Honda CB750K 6
