Page 1 of 3
GT1000
Posted: Wed Feb 11, 2009 2:05 am
by shannon
boys and girls..
the 1000 engine is in its final stages and will get its shakedown in 2 weeks time at the speedtrials, lake gairdner, south OZ..
Im riding the bike if i can get the time off work and we are also taking a T500 down..
i will be taking lotsa pics and hopefuly can get the helmet cam sorted..
this was a test barrel... one cylinder on the dyno was making about 68hp at the rear at 7000 rpm and 45 ft/lb tourque..
the cracks are due to impurities in the alloy.. high iron content....
that has been sorted and the new pour was perfect!!
Posted: Wed Feb 11, 2009 2:47 am
by Craig380
Wow! That's impressive work.
But one thing bothers me ... I'm not sure those inlets are big enough :wink: :D
But seriously, great stuff, keep us posted
Posted: Wed Feb 11, 2009 5:34 am
by Suzukidave
Wow .. Brett's doing some awesome work there . over 200hp :D so thats what it would take to get the old GT up to todays performance standards :shock:
Posted: Wed Feb 11, 2009 6:04 am
by shannon
yep, extremely impressive, and the interesting thing is that those exhaust ports are smaller than the tr750.. less than 33% of the circumfrnce... ideally you could push the exhaust are to over 80% of the area if there is enough ring support and what you see there is close to 60% with room for more now that that water passages have been moved.
each inlet holds a block of 2 x rgv250 reed assemblies and carbs are 44mm mikuni's.
Posted: Wed Feb 11, 2009 9:24 am
Shannon,
That's an impressive piece of work. It seems to be the logical next step in Brett's development with the welded block. The liner design is similar, as is are the ports to the crankcase for example - a logical progression.
I didn't realize that RGV reed cages were so large. I only have RS250 Aprilia cages and they are wide but not very tall and their port area is not as large as one might expect. Those look to be much larger. But with two per port that's a lot of port area. What do the intake manifolds look like?
I like those boysen ports between the intakes and transfer passages. Did those prove to be useful on the dyno in broadening the powerband? I have read mixed reviews on them. It seems that some engines respond well and on others it makes no difference.
Not that you need more power, but did you consider rotating the cylinders to a straight forward position? It makes the ports more effective because the gas gets a straighter shot.
It would require a whole new pattern and I have no idea how the heck that would be created. Even more work I guess.
Good luck and keep us posted
teazer
Posted: Wed Feb 11, 2009 9:25 am
Shannon,
What ignition is going on that beast? I recall Brett used an MSD 6 at one time, but I don't know what he used to trigger it.
Same on this or something new?
Posted: Tue Feb 17, 2009 7:32 am
by Suzukidave
Any updates you can share with us Shannon :D
Updates on Shannon's GT1000
Posted: Thu Feb 26, 2009 11:17 pm
by Kris Bernstein
Lovely stuff!
Any plans to market the GT1000 blocks and heads?
Who is doing the 1000 pistons?
Any pictures of the cylinder head(s)???
If you make these available, I'll take two!!
Kris Bernstein
Re: Updates on Shannon's GT1000
Posted: Fri Feb 27, 2009 8:45 am
by husson73
Kris Bernstein wrote:Lovely stuff!
Kris Bernstein
You are on the way to build a 2000 cc ? on line or V engine? :P :D :lol: 8)
"You are on the way to..."
Posted: Fri Feb 27, 2009 7:34 pm
by Kris Bernstein
Sorry, I'm not understanding what it is you are saying, Hunnsan.
Please explain...
Kris
hold the presses, i understand....====
Posted: Fri Feb 27, 2009 7:39 pm
by Kris Bernstein
Oh, I re-read your comments and no, I have two GT/TR750 motors I'm using for road racing and would like to get two of these top end assemblies.
I am also thinking Shannon might want a supplier/distributor for North America if he goes into full production.
These motors will piss off a bunch of otherwise smug TZ750 racers, me thinks...:)=
Kris
gt1000
Posted: Sat Feb 28, 2009 7:08 pm
by shannon
Kris.. Not my handy work but a life long friend.
more info later, but it will get its full shakedown next weekend at lake gairdner ( the aussie equivalent of bonneville)
I have a modified seeley TR500 that i am taking, along with the 1000 that i will be throwing a leg over..
If all things go well, then im sure that they might be available but not cheap.. the labour to make these has been countless..
I now have the basic core and pattern and I would like to keep a 750 version with some changes to port area, in particular the exhaust port.
Our racing laws and eligibility are fairly strict here so we cant get away with some of the stuff that you can.
anyways, must get off the computer.. busy trying to mount up a fuel pump to the TR.. the 38 mikuni's suck the bowls dry in under a minute at full noise. probably not a good thing on a 7 mile straightaway!!
Posted: Sat Feb 28, 2009 7:44 pm
by Suzukidave
Hi Shannon .. good stuff seeing the progress on the 1000cc motor . Are you useing a electric or vaccum fuel pump on the 500 ?
Posted: Sun Mar 01, 2009 12:21 am
Is it fair to say that this block is not exactly a bolt on accessory.
Some "assembly" required.
GT1000 update
Posted: Sun Mar 01, 2009 2:46 am
by Kris Bernstein
Thanks for the update Shannon. Best of luck on the salt.
We may be blessed (or cursed) with more liberal rules about what is "vintage" but it does make for some interesting development.
We to run an original Seeley 750 that ran at Daytona in 1974. Always on the look out for go fast goodies.
Keep us in the loop!
Kris
