Gt250K forks
- Suzuki 2-Strokes: 1973 GT250
Gt250K forks
Hi all. Recently picked up a 73 Gt250 and whilst I owned one back in the seventies, I don't recall the front forks topping out as this one does when putting it on the centre stand or riding on rough roads under acceleration which results in a hefty clunk!. Forks have been overhauled by the previous owner and have fresh oil ( transmission fluid by the look of it) any thoughts or advice would be much appreciated. Thanks
Re: Gt250K forks
Check the fork spring sag. Its how much the forks compress going from no weight on the forks to you sitting on the bike & barely using your feet to balance the bike.
- Country: England, UK
Re: Gt250K forks
I wonder if he reassembled incorrectly. Possibly he omitted a ring or assembled in the wrong order? Springs might have sagged, as already mentioned. Or there could be insufficient oil.
Since it goes bang I would consider the damping being faulty. Check the amount of oil is correct. If that doesn't fix it, strip and check the assembly against a parts diagram to see if he has put it back together incorrectly.
Re: Gt250K forks
I was thinking along the same lines that it may be a damper issue as the rebound is fairly instant without much control. In terms of fork oil grade, I know may people use atf fluid but I'm unsure what SAE that is compared to conventional 10 or 5W.
Re: Gt250K forks
I see that Suzuki specified SAE 30w for the forks, I presume using a much lower weight oil as has been used in my bike would result in the poor rebound damping I'm experiencing . Any advise would be welcome.
Re: Gt250K forks
The GT250 had rebound damping? The GT380 of the same era didn't. That is why so many guys modify their shocks to give them a little.
Dollydog is the resident GT250 expert on here. He might be able to tell you if they had rebound damping or not and how to counteract your problem
Re: Gt250K forks
Well when I said 'Rebound damping', what I meant was returning from compression!......Think I've found the issue, only 100cc of oil in each leg, think its supposed to be 220!
Re: Gt250K forks
Yes according to Suzuki service manual 220cc is correct. Glad you found the solution!Tapnell wrote:Well when I said 'Rebound damping', what I meant was returning from compression!......Think I've found the issue, only 100cc of oil in each leg, think its supposed to be 220!
I knew what you meant by rebound damping. According to this guide http://www.ozebook.com/compendium/suzi/ ... AtHome.pdf" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
"Compression damping on the mid-sized Suzukis is fine, but rebound is way too light."
From that I would assume most of the Suzuki bikes of the era were similar. However, that doesn't mean to say they can't be a lot of fun!
