Thanks Frank - that puts it in the middle of the range - and it is a Mk II ?Frank T wrote:The VIN on my '69 T500 is 22298.
T500 Frame and Engine Numbers
Re: T500 Frame and Engine Numbers
- Suzuki 2-Strokes: 68 Cobra, 73T500
Yes it is a mk II with a GT500 front end.
Frank Tarpley
1968 Cobra, 1973 T500, 1974 GT380, 1987 Yamaha RZ350, 1988 Yamaha TDR250, 1989 DT50
Nice !
The Vin on my '69 is 20085. I have a pair of Cobras - one with 12666 and the other is 14XXX (sorry I don't recall the last three digits right now). My '70 T500 III is 27691.
As I understand it, the frame and engine numbers matched until some time in the 1973 model year when something went awry in Hamamatsu between the frames and the engines.
My 68's, 69, 70, and 71 all have matching frame and engine numbers. My '75 does not.
Hope this helps!
Jim
Hope this helps!
Jim
Frank,
That is a stunning 1969 T500 and is the color I want to paint mine when I start rebuilding it.
Jim
Jim
Thanks Frank and Jim - I have added those to the list I've started keeping. As these pop up here and there what I'll do is make a note of high and low numbers in the production range - so not a registry as such, but just attempting to zero in on the model change points. The later years appear to be fairly well documented so the focus is more on the very early ones, and as well on the highest 'B' model numbers recorded.
I may be able to share the spreadsheet easily via a URL - still looking at options.
The spreadsheet I'm using to track the early frame numbers it can be found at this link . If you own an early T500 model 500/5, MK1, MkII, MkIII or a model B that has a frame and/or engine number lower or higher than what I've listed then I'd like to hear from you !
1968 T500 sold on eBay on July 31, 2011 by Paul Miller. VIN T500-10221
1968 T500 sold on eBay on August 21, 2011. VIN T500-14223
My topic:
viewtopic.php?f=2&t=4609&start=15
eBay sales:
http://cgi.ebay.com/ebaymotors/1968-Suz ... 0634764916
http://cgi.ebay.com/ebaymotors/1968-Suz ... 0361459053
My topic:
eBay sales:
- Suzuki 2-Strokes: Now T500, previous TS185, GS750, GS1000
Hello all, glad everyone would like to get these things sorted out so the more data the better. My Cobra has a matching VIN / Engine number, 13558 - as we know the ID plate on the steering column has no manufacture date but this bike has always been titled as a 1968 (purchased new in Iowa in '68 by original owner). My 1970 T500-III also has matching VIN / Engine number 29227 and the ID plate gives a build date of May 1970. Do the 1969 Mark II models feature ID plates with build dates? If so, would be nice if members with Mark II and Mark III models could report build dates here too.
1968 Suzuki T500 Cobra
1970 Suzuki T500 Mark III [rebuild project]
1970 Kawasaki 500 Mach III - H1
1975 Kawasaki 750 Mach IV - H2
1970 Yamaha R5 350
1984 Yamaha RZ350L [acquired September 2015]
1970 Yamaha R5 350
Does the ID plate on the steering column for the 69 model have a manufacture date on it? My 1970 ID plate has a manufacture date stamped on the top and the VIN number stamped on the bottom...Frank T wrote:The VIN on my '69 T500 is 22298.
1970 Yamaha R5 350
1970 Yamaha R5 350
If it's not too much trouble can you find the manufacture or build dates on your 69 and 70 models? My 1970 model has a manufacture date stamped on the top of the ID plate and the VIN is on the bottom... see my other posts for relevant information.diamondj wrote:The Vin on my '69 is 20085. I have a pair of Cobras - one with 12666 and the other is 14XXX (sorry I don't recall the last three digits right now). My '70 T500 III is 27691.
Hope this helps!
Jim
1970 Yamaha R5 350
1970 Yamaha R5 350
Yeah sorry too much trouble....ericsattic wrote:If it's not too much trouble can you find the manufacture or build dates on your 69 and 70 models? My 1970 model has a manufacture date stamped on the top of the ID plate and the VIN is on the bottom... see my other posts for relevant information.
Just kidding! The '69 does NOT have a build date. The data tag is the same style as the '68. The '70 however was built in April of 1970 and has the later style data plate.
I also noted the VIN on my later '68 which is T500-14751
Jim
Thanks - I've added it.jabcb wrote:1968 T500 sold on eBay on July 31, 2011 by Paul Miller. VIN T500-10221
This appears to be both an 11 fin barrel, and also a long wheel base frame - if true, then Diamond J's comment about the number of 500/5's being in the low hundreds may be optimistic
Added - thank you !ericsattic wrote:My 1970 T500-III also has matching VIN / Engine number 29227
I think the 10 fin barrel is a T500 "urban legend" based on a moto-journalist miscounting and it's been passed along as truth ever since. I've never seen one and for years I counted fins until I gave up on it as a myth.oldjapanesebikes wrote:Thanks - I've added it.jabcb wrote:1968 T500 sold on eBay on July 31, 2011 by Paul Miller. VIN T500-10221
This appears to be both an 11 fin barrel, and also a long wheel base frame - if true, then Diamond J's comment about the number of 500/5's being in the low hundreds may be optimisticIt may also mean that the 10 fin barrels, contrary to the period press of the day, were not very standard at all.
I had heard the short wheelbase T500's numbered around 250 or less but that number is obviously lower. Cyclebuster posted his Cobra's VIN was T500-10203 and his does not have a short wheelbase either. The short wheel base T500 I saw in person was sub 100 on the VIN number and is owned by Paul Miller.
Jim
