Suzuki T500M Gear Shift Return Spring Replacement
- gav1n
- Country: england
- Suzuki 2-Strokes: suzuki t500
T500m gear change return spring "can it be replaced without splitting the crankcase halves"My bikes gearchange does not now return on the downward shifts stays down started this morning on my way home from work it's been ultra reliable blotted its copy book cheers Gavin
- Country: us
- Suzuki 2-Strokes: GT
Re: Suzuki T500M Gear Shift Return Spring Replacement
You shouldn't need to split cases,you will need to pull clutch cover,may need to pull clutch, remove shifter shaft from clutch side of gearbox,the spring is around shifter shaft.Check to be sure shifter shaft is free and not hanging up.
- gav1n
- Country: england
- Country: us
Sounds like a broken return spring is a possibility,especially if it started suddenly.
